Homework Help: Fluid mechanics problem
  1. May 2, 2012 #1
    A horizontal bend in a pipeline conveys water at a discharge at 1000l/s gradually reduces from 600mm to 300mm and deflects the flow through an angle of 60 degrees. At the larger end the pressure is 170000N/m^2. Determine the magnitude and direction of the force exerted on the bend.
    2. Relevant equations
    How can I find pressure2 (at point 2 300mm end)
    is my solution right to find pressure at point 2
    Please help as i need solution urgently. Thanks to all
    3. The attempt at a solution
    I have used moment to find internal force F=DENSITY * FLOW DISCHARGE (V2-V1)
    Than I have used the formula F=P/A to find the pressure.
    Q(FLOW DISCHARGE) =AV (AREA*VELOCITY)
    P.s if i find p2 i can use formula to find external forces on the bend using
    P1A1-P2A2COSTHETA -Fx= DENSITY*Q*(V2*COSTHETA-V1)
    Fy-P2A2SINTHETA= DENSITY*Q*(V2*SINTHETA)
  3. May 3, 2012 #2
    Hint: Bernoulli equation
