Derivations for Continuity equation of Fluid & Euler's Equation of Fluid Motion
In summary, we discussed the derivation of the continuity equation and Euler's equation of fluid motion. The continuity equation states that the time rate of change of mass in a control volume, plus the net outward flux of mass through its surface, is equal to zero. This can be expressed in both integral and differential form using the Divergence Theorem. The momentum equation, on the other hand, states that the time rate of change of momentum in a volume, plus the net outward momentum flux through the surface, is equal to the net force on the fluid. This equation can also be expressed in both integral and differential form, and is composed of three separate equations for the x, y, and z components of momentum. Finally, we discussed the
Shan K
73
Will anyone give me the derivations for continuty equation of fluid and euler's equation of fluid motion .
So just in case you aren't familiar with the Reynolds Transport Theorem, I will start before that. Also note I am leaving it all as single integrals rather than introducing double and triple integrals. The domain of integration should make it obvious what it means.
Starting with the continuity equation. We can state, in words, the conservation of mass in an Eulerian frame as:
The time rate of change of mass in a control volume, [itex]\mathscr{V}[/itex] plus the net outward flux of mass through its surface, [itex]A[/itex] is identically equal to zero.
First we will talk about the time rate of change of mass in the volume. We define the following:
Mass in volume [itex]d\mathscr{V}[/itex]: [tex]\rho\;d\mathscr{V}[/tex]
Mass in volume [itex]\mathscr{V}[/itex]: [tex]\int\limits_{\mathscr{V}}\rho \; d\mathscr{V}[/tex]
Time rate of change of mass in volume [itex]\mathscr{V}[/itex]: [tex]\int\limits_{\mathscr{V}}\frac{\partial \rho}{\partial t} \; d \mathscr{V}[/tex]
Next we address the outward mass flux across the surface:
Mass flux per area: [tex]\rho \bar{V}[/tex]
Mass flux through [itex]dA[/itex]: [tex]\rho \bar{V} \cdot \hat{n}\; dA[/tex]
Mass flux through [itex]A[/itex]: [tex]\oint\limits_{A}\rho \bar{V} \cdot \hat{n}\; dA[/tex]
So combining these terms to form the integral form of the continuity equation gives
[tex]\int\limits_{\mathscr{V}}\frac{\partial \rho}{\partial t} \; d \mathscr{V} + \oint\limits_{A}\rho \bar{V} \cdot \hat{n} \; dA = 0[/tex]
From here, we can use the Divergence Theorem (Gauss' Theorem) to change the second term to a volume integral.
[tex]\oint\limits_{A}(\rho \bar{V}) \cdot \hat{n} \; dA = \int\limits_{\mathscr{V}}\nabla \cdot (\rho \bar{V}) d\mathscr{V}[/tex]
This can be substituted into the previous equation to get
[tex]\int\limits_{\mathscr{V}}\left[\dfrac{\partial \rho}{\partial t} + \nabla \cdot (\rho \bar{V})\right] d\mathscr{V} = 0[/tex]
For this to be satisfied in general, the integrand must be zero, so the differential form of the continuity equation is
[tex]\boxed{\dfrac{\partial \rho}{\partial t} + \nabla \cdot (\rho \bar{V}) = 0}[/tex]
You can also use the definition of the material derivative to put it in its slightly more popular form
[tex]\boxed{\dfrac{D\rho}{Dt} + \rho \nabla \cdot \bar{V} = 0}[/tex]
Moving onto the momentum equation, we can state the conservation law in words as
The time rate of change of momentum in [itex]\mathscr{V}[/itex] plus the net outward momentum flux through [itex]A[/itex] equals the net force on the fluid.
Using the same method as before to define each term, we can say that
Momentum per volume: [tex]\rho\bar{V}[/tex]
Momentum in volume [itex]d\mathscr{V}[/itex]: [tex]\rho\bar{V}\;d\mathscr{V}[/tex]
Momentum in volume [itex]\mathscr{V}[/itex]: [tex]\int\limits_{\mathscr{V}}\rho\bar{V}\;d\mathscr{V}[/tex]
Time rate of change of momentum in [itex]\mathscr{V}[/itex]: [tex]\int\limits_{\mathscr{V}}\dfrac{\partial}{\partial t}(\rho\bar{V})\;d\mathscr{V}[/tex]
Next, the outward momentum flux term can be addressed as follows:
Momentum flux per area: [tex](\rho\bar{V})\bar{V}[/tex]
Momentum flux across [itex]dA[/itex]: [tex](\rho\bar{V})\bar{V}\cdot\hat{n}\;dA[/tex]
Momentum flux across [itex]A[/itex]: [tex]\oint\limits_{A}(\rho\bar{V})\bar{V}\cdot\hat{n}\;dA[/tex]
In addressing the forces on the fluid, we split the possible forces into two categories: body forces and surface forces. The body forces (such as gravity) are handled as follows:
Body force per unit mass: [tex]\bar{f}[/tex]
Body force per unit volume: [tex]\rho \bar{f}[/tex]
Body force on volume [itex]d\mathscr{V}[/itex]: [tex]\rho \bar{f}\;d\mathscr{V}[/tex]
Body force on volume [itex]\mathscr{V}[/itex]: [tex]\int\limits_{\mathscr{V}}\rho \bar{f}\;d\mathscr{V}[/tex]
The surface forces typically are represented by the stress tensor, but since we are assuming inviscid flow here (as per the assumptions of Euler's equation), we can ignore viscosity and deal only with pressure forces.
Force due to pressure on [itex]dA[/itex]: [tex]-p\hat{n}\;dA[/tex]
Force due to pressure on [itex]A[/itex]: [tex]-\oint\limits_{A} p\hat{n}\;dA[/tex]
So pulling all this together according to our stated conservation law, we can write the integral form of the momentum equation as
[tex]\int\limits_{\mathscr{V}}\frac{\partial}{\partial t}(\rho \bar{V}) \; d \mathscr{V} + \oint\limits_{A}(\rho \bar{V})\bar{V} \cdot \hat{n} \; dA = \int\limits_{\mathscr{V}}\rho \bar{f} \; d \mathscr{V} - \oint\limits_{A} p\hat{n}\;dA[/tex]
Here again, we make use of the divergence theorem to say that
[tex]\oint\limits_{A} p\hat{n}\;dA = \int\limits_{\mathscr{V}}\nabla p\;d\mathscr{V}[/tex]
This gives
[tex]\int\limits_{\mathscr{V}}\frac{\partial}{\partial t}(\rho \bar{V}) \; d \mathscr{V} + \oint\limits_{A}(\rho \bar{V})\bar{V} \cdot \hat{n} \; dA = \int\limits_{\mathscr{V}}\rho \bar{f} \; d \mathscr{V} - \int\limits_{\mathscr{V}}\nabla p\;d\mathscr{V}[/tex]
This is a vector equation and so really represents 3 equations. For grins, let's look at the x-momentum equation first.
[tex]\int\limits_{\mathscr{V}}\frac{\partial}{\partial t}(\rho u) \; d \mathscr{V} + \oint\limits_{A}(\rho u)\bar{V} \cdot \hat{n} \; dA = \int\limits_{\mathscr{V}}\rho f_x \; d \mathscr{V} - \int\limits_{\mathscr{V}}\dfrac{\partial p}{\partial x}\;d\mathscr{V}[/tex]
The Divergence Theorem let's us change the flux term to
[tex]\oint\limits_{A}(\rho u \bar{V})\cdot\hat{n}\;dA = \int\limits_{\mathscr{V}}\nabla \cdot (\rho u \bar{V})\;d\mathscr{V}[/tex]
So we have
[tex]\int\limits_{\mathscr{V}}\frac{\partial}{\partial t}(\rho u) \; d \mathscr{V} + \int\limits_{\mathscr{V}}\nabla \cdot (\rho u \bar{V})\;d\mathscr{V} = \int\limits_{\mathscr{V}}\rho f_x \; d \mathscr{V} - \int\limits_{\mathscr{V}}\dfrac{\partial p}{\partial x}\;d\mathscr{V}[/tex]
[tex]\int\limits_{\mathscr{V}}\left[ \frac{\partial}{\partial t}(\rho u) + \nabla \cdot (\rho u \bar{V}) - \rho f_x + \dfrac{\partial p}{\partial x} \right] \;d\mathscr{V} = 0[/tex]
Setting the integrand to zero to solve the equation in general gives
[tex]\boxed{\frac{\partial}{\partial t}(\rho u) + \nabla \cdot (\rho u \bar{V}) = \rho f_x - \dfrac{\partial p}{\partial x}}[/tex]
Using an identical process, you can get the y- and z-momentum equations
[tex]\boxed{\frac{\partial}{\partial t}(\rho v) + \nabla \cdot (\rho v \bar{V}) = \rho f_y - \dfrac{\partial p}{\partial y}}[/tex]
[tex]\boxed{\frac{\partial}{\partial t}(\rho w) + \nabla \cdot (\rho w \bar{V}) = \rho f_z - \dfrac{\partial p}{\partial z}}[/tex]
Now, continuing to play with the x-momentum equation further, we can expand the divergence term and the density derivative
[tex]\rho\dfrac{\partial u}{\partial t} + u\dfrac{\partial \rho}{\partial t} + u\nabla \cdot (\rho \bar{V}) + \rho\bar{V} \cdot \nabla u = -\dfrac{\partial p}{\partial x} + \rho f_x[/tex]
If we multiply the continuity equation by [itex]u[/itex] we get
[tex]u\dfrac{\partial \rho}{\partial t} + u\nabla \cdot (\rho \bar{V}) = 0[/tex]
which shows up in our momentum equation and can be zeroed. This leaves behind
[tex]\rho\dfrac{\partial u}{\partial t} + \rho\bar{V} \cdot \nabla u = -\dfrac{\partial p}{\partial x} + \rho f_x[/tex]
which, after recognizing the material derivative, becomes one component of the Euler equation:
[tex]\boxed{\rho\dfrac{Du}{Dt} = -\dfrac{\partial p}{\partial x} + \rho f_x}[/tex]
The y- and z-components are
[tex]\boxed{\rho\dfrac{Dv}{Dt} = -\dfrac{\partial p}{\partial y} + \rho f_y}[/tex]
[tex]\boxed{\rho\dfrac{Dw}{Dt} = -\dfrac{\partial p}{\partial z} + \rho f_z}[/tex]
This can be denoted in vector form as
[tex]\boxed{\rho\dfrac{D\bar{V}}{Dt} = -\nabla p + \rho \bar{f}}[/tex]
which is the standard form or Euler's equation.
I can't understand why the mass flux is p(rho)v . I also can't understand why you had taken a minus sign when you calculated the force due to pressure on dA in the second derivation
I think bone deserves real thanks for the effort he must have put into his post.
Think of a pipe volume/second = volume flux = area cross section x velocity.
so mass flux = density x volume flux
and mass flux / area (which is what Bone wrote) =ρAv / A = ρv
Bone is discussing a control volume with the outward direction positive and the inward direction negative.
That is the force is due to the inward pressure acting on the control volume.
Many many thanks to both of u . And a special thanks to boneh3ad .
Haha, no problem. Don't be too impressed though, I just got done (this morning) writing up some notes on this topic for the class I am teaching, so I had probably 60% of the LaTeX already written right here next to me. :)
Still a pretty impressive answer though.
1. What is the Continuity equation of Fluid?
The Continuity equation of Fluid is a fundamental equation in fluid dynamics that expresses the conservation of mass for a fluid. It states that the rate of change of mass in a given volume of fluid is equal to the net flow of mass into or out of the volume.
2. How is the Continuity equation of Fluid derived?
The Continuity equation of Fluid is derived from the principle of conservation of mass, which states that mass is neither created nor destroyed. By considering a small volume of fluid and applying this principle, we can arrive at the Continuity equation.
3. What is Euler's Equation of Fluid Motion?
Euler's Equation of Fluid Motion is a fundamental equation in fluid dynamics that describes the motion of an inviscid (non-viscous) fluid. It combines the concepts of conservation of mass, conservation of momentum, and conservation of energy to describe the acceleration of a fluid element.
4. How is Euler's Equation of Fluid Motion derived?
Euler's Equation of Fluid Motion is derived from Newton's Second Law of Motion, which states that the net force acting on an object is equal to its mass times its acceleration. By considering a small element of fluid and applying this law, we can arrive at Euler's Equation.
5. What are the assumptions made in deriving the Continuity equation and Euler's Equation?
The main assumptions made in deriving the Continuity equation and Euler's Equation are that the fluid is incompressible (i.e. its density does not change), inviscid (i.e. it has no internal friction), and the flow is steady (i.e. it does not change with time). Additionally, Euler's Equation assumes that the flow is irrotational (i.e. the fluid particles do not rotate as they move). These assumptions allow for simplified mathematical descriptions of fluid flow and are appropriate for many real-world applications.
  • Mechanics
