Fluid Pressure problem
  1. Feb 25, 2012 #1
    Hi I have a midterm study guide question. This one has stumped me for a while and probably the only one undone.
    Suppose there is a semi-circular plate of radius 5 ft that rests on its
    diameter and is tilted at 45 degree angle to the bottom of a tank lled with water to depth
    6 feet. Find the force exerted by the water against one side of the plate. (The
    weight-density of water is 62.4 lb=ft^3)
    2. Relevant equations
    So I'm reading the book and I know that to solve the problem Force is weight-density of water (62.4) times the depth (6-y) and the area.
    Now the problem is I'm not quite sure how to approach the area. I just can't seem to grasp the image of the tank. Not to mention the 45 degree angle really confused my approach. I was under the assumption that its a 6ft tall cylinder with length 10ft and a plate on the bottom tilted at 45 degrees
    3. The attempt at a solution
    Problem seems simple, but I can't seem to figure out the 45 degree plate to find the area.
    What i have is:
    Integral from 0 to 6 of (62.4)(6-y)(area)
    Now this is assuming that I approached this correctly.:confused:
  3. Feb 25, 2012 #2
    tiny-tim
    Welcome to PF!
    Hi NoobDoingMath! Welcome to PF! :smile:
    Yes, that's basically correct.
    You seem to be confused about the area …
    I suggest in future you always use the slicing method.
    In this case, slice the plate into horizontal slices of vertical distance dy …
    then find the area of that slice (it'll be dy√2 times the width, won't it?) :wink:
  4. Feb 25, 2012 #3
    Still a little bit confused, and I want to see if I'm understanding correctly. My "math English" isn't too good. :shy:
    So √2 is a result of the 45-45-90 triangle right?
    Therefore the slice is √2dy*width
    The width is 10ft since its radius is 5 and the plate rest on its diameter?
    Resulting my solution to be:
    ∫(62.4)(6-y)(10√2)dy a=0, b=6
    My answer would become:
    11232√2
  5. Feb 26, 2012 #4
    tiny-tim
    Hi NoobDoingMath! :smile:
    (just got up :zzz:)
    Nooo, you're not thinking straight. :redface:
    Or, rather, you are thinking straight, and you should be thinking circular! :biggrin:
    The width has to be the width of the slice
    that's the whole point of slicing …
    you add the area of each slice, and that depends on y, doesn't it? :wink:
    Try again! :smile:
