Fluid Problem: Force on a Metal Cube Immersed in Water
  • Thread starter koolraj
  • Tags
    Fluid
In summary, when a metal cube is placed in an empty vessel and water is filled to completely immerse the cube, the force on the bottom of the vessel in contact with the cube will decrease. This is because the buoyant force exerted by the water on the cube decreases the normal reaction force exerted by the cube on the vessel. While the book states that the force remains constant, further analysis suggests that the force actually decreases.
koolraj
metal cube is placed in an empty vessel. When water is
filled in the vessel so that the cube is completely immersed in the
water, the force on the bottom of the vessel in contact with the
cube:
(a) Will decrease
(b) Will increase
(c) Will remain same
(d) Will become zero
i tried the ans i think it's (a) will decrease.but book say's (c)it remains constant
Consider the two cases case1) when vessel is empty
Case2) when vessel is filled with water
Let w=weight of the metal cube (in air)
N=normal reaction exerted by cube on the vessel in absence of water
R= normal reaction exerted by cube on the vessel in presence of water
B= Buoyancy force (=weight of fluid displaced by the block)
Then by drawing the free body diagram of metal cube in each case as shown in fig. above we have
Case 1)w=N
Case 2)w=R+B
i.e. R=w-B. Thus the reaction on cube(by the vessel) in presence of water decreases due to the Buoyant force. Hence, the force on the bottom of the vessel in contact with the cube decreases
I agree with your answer and not that of the book. Maybe we're missing something?
1. What is fluid mechanics?
Fluid mechanics is a branch of physics that deals with the study of fluids (liquids and gases) and the forces that act on them. It is concerned with understanding how fluids behave under different conditions and how they interact with solid objects.
2. What is the force on a metal cube immersed in water?
The force on a metal cube immersed in water is equal to the weight of the water that the cube displaces. This is known as Archimedes' principle, which states that the upward buoyant force on an object in a fluid is equal to the weight of the fluid that the object displaces.
3. How is the force on a metal cube affected by its size and shape?
The force on a metal cube depends on its volume, shape, and density. The larger the cube, the more water it will displace and the greater the buoyant force will be. The shape of the cube also affects the force, as a cube with a larger surface area will experience more resistance from the water and therefore a greater force.
4. How does the density of the metal cube affect the force on it?
The density of the metal cube plays a crucial role in determining the force on it. If the density of the metal cube is greater than that of water, it will sink and experience a downward force from the weight of the water above it. If the density is less than that of water, it will float and experience an upward force from the buoyancy of the water.
5. What other factors can affect the force on a metal cube immersed in water?
The force on a metal cube can also be affected by the properties of the water, such as its density and viscosity. The depth of the water and the surrounding pressure can also have an impact on the force. Additionally, any external forces acting on the cube, such as a current or wind, can alter the force experienced by the cube.
