Homework Help: Fluid problem
  1. Nov 13, 2015 #1
    • Poster has been reminded to show their Attempt at a Solution in schoolwork threads
    At a processing plant, olive oil of density 875 kg/m3 flows in a horizontal section of hose that constricts from a diameter of 2.92 cm to a diameter of 1.20 cm. Assume steady, ideal flow. What is the volume flow rate if the change in pressure between the two sections of hose is 5.10 kPa?
    2. Relevant equations
    A1v1=A2V2
    3. The attempt at a solution
  3. Nov 13, 2015 #2
    SteamKing
    Staff Emeritus
    You've quoted the continuity equation, but that doesn't tell you anything about what happens to the pressure of the fluid.
    You need to find another equation which says something about the pressure of the fluid.
Have something to add?
Draft saved Draft deleted
Loading...
