Fluid Questions
  • Thread starter jefgreen
A metal object is suspended from a spring scale. The scale reads 920 N when the object is suspended in air, and 750 N when the object is completely submerged in water.
a. Find the volume of the object.
b. Find the density of the metal.
d=m/v or v=md or m=dv
D of Water=1.00x103kg/m3
1N=1kg
v=_____3
Part A: v=md
(750N)(1.00x103kg/m3)
V=7.5x105
Honestly, I'm fairly sure that ^ is completely wrong... :uhh:
Part B: d=m/v
I am completely lost..
Answers and Replies
BUMP. Help please.
Do you know about the buoyant force?
I have an equation sheet which mentions it.
Buoyant Force: Fbuoyant=DVg
I know:
Dh2o=1.00x10^3 kg/m^3
g=9.80 m/s^2
Okay, and you know that the buoyant force on a submerged body is directed in the opposite direction to gravity. It's always helpful to make a draw of what's really going on here.
So now you should think about what does the Archimedes principle states:
Real weight (920N) = apparent weight (measured as 750N) + weight of displaced fluid (buoyant force).
If you work out the maths here, you will get the volume. Don't hesitate to ask if you're not sure though.
Would I set it up like this?
920=750+(1.00x10^3)v(9.80)
and solve for v?
No, that's not the answer sorry.
I just gave you the equation that you have to use to work out the volume. It's not that tedious to plug numbers in.
950 = 720 + DVg
Letting D be the density of the fluid...
and solve for v?
Oh haha, okay you got it yeah.
And once you have the volume you can use the density equation (D = m/v) to get the density of the body.
Hope it's clear ;)
and solve for v?
I got .0872 for v.
What would I plug in for the mass?
d=m/v
D=M/.0872
What would I plug in?
Oh, when calculating the density, you should think that it is not important in which surroundings are you doing it, because rigid bodies will always have the same density. So for the density you should basically search what's the real mass of the body i.e.:
real weight (920) = M(Kg) · g(9.81m/s^2)
So...
920/.0872 will give me Density? :confused:
Nope, 920N is the weight. Weight and mass are two different things, the mass can be calculated as:
M = weight/gravity
Hence, M = 93.78Kg. Now you can plug this M in the density formula.
So the answer Part B is:
D=93.78kg
.0872
which equals 1075.458716 or 1.1x10^3?
Is v= .0872 correct, by the way?
D=93.78kg
.0872
As long as your volume was .0872, that should be right. But check that out concerning the volume:
920-750 = 9.81 x 10^3 x V, are you sure that V is .0872?
No, v definitely is not .0872.
To find v do I set it up like this?
920-750=(9.80)(1.00x10^3)v
V=.0173 is what I have now...
Yeah, that's what I was wondering, I think you did some kind of algebra error or calculator typo, because I keep getting .0173 for the Volume.
Check now for the density as:
D = 93.78Kg / .0173m^3
Answers:
Part A: V=.0171 m^3
Part B: D= 5.4x10^3
Is this correct? Also, what unit would density be in?
Yeah, that is numerically correct. Now for the units of the density, if we have:
D = m/V, we should know that mass is in (Kg) and V in (m^3], so density is just (Kg/m^3).
Thank you so much. :smile:
Related Threads on Fluid Questions
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
