Homework Help: Fluid Statics
  1. Apr 18, 2017 #1
    (a) A rectangular gasoline tank can hold 39.0 kg of gasoline when full. What is the depth of the tank if it is 0.450 m wide by 0.900 m long?
    m
    (b) What is the volume of the tank? (It is suitable for a passenger car.)
    gal
    2. Relevant equations
    Density of gas=719.7=mass/volume
    Volume=lengthxwidthxheight
    density=mass/volume
    density=mass/ (lengthxwidthxheight)
    3. The attempt at a solution
    I assumed depth was referring to the height, which might be what I'm doing wrong.
    719.7=39/ (.45 x .9 x h)
    height=.1338m
    And then I would convert the volume (.45 x .9m x .1338m) to gallons using (1 gal=.003785 m3)
    This seems fairly straight forward, but for some reason this answer is wrong. Please help!
    Thanks
  3. Apr 18, 2017 #2
    TSny
    2017 Award
    You work looks correct to me. What did you get for the number of gallons?
  4. Apr 18, 2017 #3
    The depth of .1338m was incorrect, so I knew the volume would be and didn't do the calculation. I've checked my math, and I still get .1338m
  5. Apr 18, 2017 #4
    TSny
    2017 Award
    The density of gasoline can vary. Were you given a particular value for the density?
  6. Apr 18, 2017 #5
    No, no value was given. I googled this value.
  7. Apr 18, 2017 #6
    TSny
    2017 Award
    Are you using a textbook that has a table of densities?
  8. Apr 18, 2017 #7
    No, I just searched through the textbook and I do not see table of densities.
  9. Apr 18, 2017 #8
    TSny
    2017 Award
    OK. Although Wikipedia gives 719.7 kg/m3, they also state, "Finished marketable gasoline is traded with a standard reference of 0.755 kg/L", which is 755 kg/m3. Several other sites give values between 730 and 750 kg/m3. So, it's hard to say what value you should use.
  10. Apr 18, 2017 #9
    Thank you-I am going to clarify with professor
Have something to add?
Draft saved Draft deleted
