Fluid statistics
  • Thread starter Nhlaka
A u-shaped tube open to air at both ends contains some mercury. A quantity of water is carefully poured into the left arm of the tube until the vertical height of water is 15 cm.
(a)What is the gauge pressure at the water-mercury interface?[ans 1.47*10^3Pa]
(b)calculate the vertical distance h from the top of the mercury in the right-hand arm of the tube to the top of the water in the left-arm.[ans 13.9 cm]
(a) p=p_0 +rho*g*h
p = 0 + 13.6*10^3 *9.8*0.15
p= 1.99*10^4
(b) 13-1.47=13.5
Answers and Replies
Doc Al
Mentor
44,988
1,259
(a) p=p_0 +rho*g*h
p= 1.99*10^4
Check your value for the density of water.
The answers are already given in brackets so my problem is deriving them:confused:
Doc Al
Mentor
44,988
1,259
You gave an attempted solution and I stated why it was wrong. Did you look up the density of water?
Thanks a million realy appreaciate:smile:
How do i then tickle (b) im totally clueless on that
Doc Al
Mentor
44,988
1,259
Draw a picture. Hint: At the same vertical position (height), the pressure must be the same. Imagine a horizontal line that intersects the mercury/water boundary.
Thank you very much Pf mentor i got the solution to the question:smile::smile:
