Fluid velocities
  • Thread starter speedy46
A pipe of 150mm bore is delivering water at a rate of 7500 liter/min at a pressure of 820 kPa. It connects via a horizontal, gradually expanding pipe, to a main of 300mm diameter. calculate the fluid velocities both in the main body of the pipe and at the outlet.
m= p1A1v1 = p2A2V2
Is the equation above correct to use for this problem. Thanks in advance.
Answers and Replies
minger
Yup, if all you're concerned about is flow rate, then continuity is all you need assuming you have areas...which you do!
Related Threads on Fluid velocities
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
13K
