Flux equation
  1. Dec 6, 2012 #1
    are both of the equations i posted flux equations. one of them is for a surface of a solid and the other is for a curve?
  3. Dec 6, 2012 #2
    If you meant "Is one of them is for a surface of a solid and the other is for a curve?", yes, the first specifically says "surface" and the second, while you have only given the form, has "ds" rather than "dS" and so is a path integral.
    Also, the first is for flux across (through) the surface in 3 dimensions while the second is for flux across the closed path, in 2 dimensions, and so the flow in and out of the region bounded by that closed path.
  4. Dec 6, 2012 #3
    well the first one is definitely a surface integral because the question says so. The second one is less obvious. The fact that there is only one integral sign might imply that the integral is over a curve...
    Is this for a larger homework question? Maybe you can tell which it is meant to be from what the rest of the question says.
Similar Threads - Flux equation Date
System of Differential Equations, Phase Plane Monday at 4:33 PM
Flux Through a Cylinder Dec 11, 2017
Flux of vector fields Dec 2, 2017
Determining between direct evaluation or vector theorems Jul 26, 2017
