Flywheel Diameter
  • Thread starter moo
moo
44
Main Question or Discussion Point
Hey all,
I realize that when weight is moved from the center of a flywheel toward the outer edge (or a larger diameter wheel is used), the capacity for energy storage increases. But I have no idea how to calculate how much that increase actually is, or whether the increase remains constant (proportionately) between the two as RPMs increase.
Anyone have a formula handy for this? Hopefully with enough footnotes for a "non-engineer" who doesn't know many standardized formula abbreviations...
Thanks, moo
__________________
moo (moo') adj. Of no practical importance; irrelevant, such as a moo point (i.e. a cow's opinion).
Answers and Replies
brewnog
Sure, a common problem.
For a solid disc:
I = mk^2 = (mr^2) / 2 = (p*pi**b*r^4) / 2
Where I is the moment of inertia of your wheel, m its mass, p the material's density, b the disc's thickness, r its radius, and k the radius of gyration.
k = r / (sqrt 2)
Now, energy stored:
E = (Iw^2)/2
Where w is the angular velocity of your wheel, (2*pi*N) where N is the number of revolutions per second.
Sorry about the lack of fancy text, write it out on paper!
For non-disc-like flywheels, you will easily be able to find I geometrically; if you struggle give us a shout or have a quick look in a mechanics book.
You following?
moo
44
Thanks guys, that should do the trick. :wink:
moo
__________________
Related Threads on Flywheel Diameter
  • Last Post
44K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
