Homework Help: Flywheel Question?
  1. Sep 28, 2006 #1
    Flywheel Question??
    Hi all I have done the following question:
    A flywheel , intially rotating at a speed of 600 rev/min, is brought to rest with uniform angular deceleration in 10 seconds.
    A) How many revolutions does the flywheel make before coming to rest?
    I used Pheta = (Wo + W)t/2 to get 314.16 rads. The I used 314.16/2Pi to get 50 revolutions
    B)Determine the magnitude and direction of the resultant linear acceleration of a point A on the flywheel 0.5seconds before coming to rest. Assume the point A is positioned at a fixed radius of 150mm from the axis of rotation.
    I firstly worked out angular acceleration to be -6.2832 rads/sec. I then found W to be 3.14 rads/sec. Using the formula for radial acceleration (ar) = w^2r I got 1.4804.
    And for tangential acceleration i got -0.94248. Therefore the resultant linear acceleration using pythagorus is 1.755. The resultant angle is tan-1(-0.94/1.48) = -32.48 degrees.
    Now whats confusing me is all the minus signs. Is this a legit answer??? The minus angle is confusing me?
    The final question is:
    C) Draw a vector diagram showing the maginitude and direction of the resultant linear acceleration and its radial and tangential components??
    Shall I draw the vector diagram using the answers above. So it will end up being in the 3rd quadrant????
    Cheers
    Do I just use the minus values worked out above.
  3. Sep 28, 2006 #2
    It might help to draw a picture of the wheel at the time of 0.5 seconds with point A at the correct position. Then draw the accelleration components. The centripetal or radial accelaration points to the center and tangential accleration is pointing the opposite direction of movement.
