FM Radio
  • Thread starter darkmagic
darkmagic
164
I bought an FM radio mono kit. After I assembled it, it works. But I want to know how to have a clear reception or signal and to acquire more stations. What should I do? Any tips or techniques? does the coil affects the signal?
Answers and Replies
darkmagic
164
a telescoping antenna, the one that can be extended/
8,199
Try moving the antenna around and moving the radio to different parts of the house to see if reception/signal strength improves. FM waves travel by line of sight, so if there is anything between the radio and the FM source, reception won't be very good.
Other than that, I don't have any electronics expertise.
darkmagic
164
I have tried that but i only get 1 station the others are not clear, what should I do with that?
berkeman
Mentor
62,893
13,782
Get a folded dipole antenna from Radio Shack. That's the one that is flexible, and looks like a "T" about arms'width wide at the top. Take off the telescoping antenna, and attach one of the two wires in the feedline to the antenna feed, and the other to your circuit common (ground). That should give you better gain, although you will need to rotate the T part around to aim at different stations.
Can you post a pic of your kit, either the one you built, or just a link to what it looks like?
darkmagic
164
i'll post a pic later. The coil included in the kit are 4 turns. Does this affect the signal or station that can be acquired? or Does the feet of those coils affect the signal?
berkeman
Mentor
62,893
13,782
What coils? I thought you said the antenna was a telescoping one?
darkmagic
164
yes. I have coils in the fm radio circuit. so does it?
berkeman
Mentor
62,893
13,782
I have no idea, but sure, the coils affect the signal coming in. I have no idea what the coil's "feet" are though.
If you could post a pic and the schematic, maybe we can offer other suggestions for increasing the receive sensitivity.
darkmagic
164
i'll do it later. i'm going out now
Suggested for: FM Radio
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
12K
37K
