Focus of a Parabola Q6ciii: Australian HSC Mathematics Extension 2 Exam
In summary, the formula for finding the focus of a parabola y^2=r^2+c^2-2cx, where r and c are constants, is (x0 + a, y0) where a is equal to -c/2 and x0 is equal to (r^2+c^2)/2c. The parabola opens to the left if c > 0 and to the right if c < 0. The focus can also be expressed as (r^2/2c, 0).
Mentallic
3,802
95
This problem is from the Australian HSC mathematics extension 2 exam. Q6ciii)
It states:
Find the focus, S, of the parabola [tex]y^2=r^2+c^2-2cx[/tex] where r and c are constants.
I couldn't figure out how to convert this into the parabola focus form (which, from the top of my head) might be [tex](x-x_o)^2=4a(y-y_o)[/tex] for the focus [tex]S(x_o,y_o+a)[/tex]
How is this done?
notice the form of x & y are reversed, so you will be looking the equation in the form
[tex](y-y_o)^2=4a(x-x_o)[/tex]
with cordinates in the focus changed as well
note that the co-efficient of y is zero, which implies y_o must be zero in the above... see how you go form here
In your formula, the parabola's vertex is at (x0, y0) and it opens upward if a > 0. The parabola you're working with opens to the left if c > 0, and to the right if c < 0.
Can you put your parabola in the form (y - y)2 = 4a(x - x0)?
Oh ok so [tex]r^2+c^2-2cx\equiv 4a(x-x_o)[/tex]
[tex]LHS=-2c(x-b)=-2cx+2cb[/tex]
therefore [tex]2cb=r^2+c^2[/tex]
then [tex]b=\frac{r^2+c^2}{2c}[/tex]
Finally, [tex]y^2=-2c(x-\frac{r^2+c^2}{2c})[/tex]
So then the focus is [tex]S(\frac{r^2+c^2}{2c}-\frac{c}{2},0)[/tex]
Is this correct?
edit: simplified, [tex]S(\frac{r^2}{2c},0)[/tex]
i haven't checked the original focus defintion, but fr0m what you give I get
[tex](y - 0)^2=4 \frac{1}{4} (r^2+c^2-2cx)[/tex]
[tex](y - 0)^2=4 (\frac{-c}{2})(x-\frac{r^2+c^2}{2c})[/tex]
so
[tex]a = \frac{-c}{2}[/tex]
[tex]x_0 = \frac{r^2+c^2}{2c} [/tex]
[tex]y_0 = 0 [/tex]
then
[tex] focus = ((x_0 + a), y_)) [/tex]
[tex] focus = ((\frac{r^2+c^2}{2c} + \frac{-c}{2}), 0) [/tex]
which look the same
1. What is the focus of a parabola?
The focus of a parabola is a fixed point within the parabola that is equidistant from the directrix and any point on the parabola. It is the point where all the reflected light rays converge.
2. How is the focus of a parabola calculated?
The focus of a parabola can be calculated using the formula (h, k + 1/4a) where h and k are the coordinates of the vertex and a is the coefficient of the squared term in the parabola's equation.
3. What is the directrix of a parabola?
The directrix of a parabola is a horizontal line that is perpendicular to the axis of symmetry and is located at a distance equal to the focal length from the vertex of the parabola.
4. How is the directrix of a parabola determined?
The directrix of a parabola can be determined by finding the distance between the vertex and the focus, and then drawing a horizontal line perpendicular to the axis of symmetry at that distance from the vertex.
5. What is the relationship between the focus and the directrix of a parabola?
The focus and directrix of a parabola are always equidistant from any point on the parabola. This means that the distance from the focus to any point on the parabola is equal to the distance from that point to the directrix.
14K
13K
  • STEM Academic Advising
