Homework Help: Football tackle force
  1. Nov 28, 2007 #1
    A 110 kg football linebacker moving at 2 m/s tackles head-on a 70 kg halfback running 4 m/s. If they have an inelastic collision, and neglecting the effects due to digging in of cleats:
    a)If the collision takes .5 sec, what is the force imparted on the halfback?
    b) what is the force imparted on the linebacker?
    2. Relevant equations
    Ft=[tex]\Delta[/tex]p
    3. The attempt at a solution
    110(2) + 70(-4) = 110v + 70v
    v= 1/3 m/s in halfback's direction
    when i solve, I get a negative force. Is this possible?
    For both a and b, i get -513.34 N, is this correct?
    a)F=(70)(.333 - 4)/.5
    F=-513.4 N
    b)F=(110)(-.333 - 2)/.5
    F=-513.4 N
  3. Nov 29, 2007 #2
    I'm not going to calculate the numbers, but using variables:
    [tex]m_1 v_1 + m_2 v_2 = (m_1 + m_2)v[/tex]
    Solve for [tex]v[/tex]:
    [tex]\frac{m_1 v_1 + m_2 v_2}{m_1 + m_2}=v[/tex]
    Using v, you can get change in momentum:
    [tex]\Delta p_1=m_1(v_1 - v)[/tex]
    [tex]\Delta p_2=m_2(v_2 - v)[/tex]
    Then you can calulate the force in each case.
    [tex]F_1=\frac{m_1(v_1 - v)}{t}[/tex]
    [tex]F_2=\frac{m_2(v_2 - v)}{t}[/tex]
    Yes, you can get a negative value for force. Force is a vector, as is velocity.
    So initially, assume the halfback is running in the positive x direction, his velocity is positive. The linebacker will be running in the negative x direction with a negative velocity.
Loading...
