For what value of x does (1/x) + (1/(1-x)) > 0
  • Thread starter Thread starter zeion
    Value
The discussion centers on solving the inequality (1/x) + (1/(1-x)) > 0. It is established that x cannot equal 0 or 1, and the expression is positive when 0 < x < 1. The user finds that the solution manual incorrectly includes x > 1 as a valid range. Testing values confirms that the inequality does not hold for x > 1, reinforcing confidence in the user's solution. The conclusion is that the solution manual contains a printing error, affirming the correct range is 0 < x < 1.
zeion
For what value of x does \frac{1}{x} + \frac{1}{1-x} &gt; 0
So I see that x not = 0 and x not = 1.
Then I added the fractions and see that it will only be positive if the bottom is positive
ie. x(1-x) > 0
I define f(x) = x(1-x) that is a parabola.
It will change signs at x = 0 and x = 1.
So I test some values in the intervals and see that it is positive when 0 < x < 1
So that is the answer.
But the solution says that it is 0 < x < 1 or x > 1?
If I put in 2 > 1 I will get (1/2) + (1/(1-2)) = (1/2)+(1/(-1) = -1/2 not > 0
Solution manuals do make mistakes. It sounds like you have a good handle on this proof technique, and have taken advantage of some sanity checks (another would be to graph 1/x + 1/(1-x)) that support your answer and conflict with the manuals, so you would have good reason to remain confident in your solution.
There's nothing to worry about,
Your answer is correct, there must have been some printing error in the solution.
It seems that the solution manual is incorrect.
edit: began my original response before others posted. Carry on...
Zeion pwned the textbook.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
