Force acting at an angle.
  • Thread starter Puneeth423
"Force acting at an angle doesn't exert pressure on a surface". Is this statement correct or wrong?
Answers and Replies
it is generaly wrong. The only angle wich wouldn;t make pressure is 90 degrees
90 degrees with the surface?
90 degrees as in parallel to the surface. Any force that has a component perpendicular to the surface will exert pressure on the surface proportional to that component. The other components of the force may not contribute to the pressure in general.
What if the force is applied acting in a direction away from the surface?
then it is a pull rather than a push...
That wasn't the answer to my question, so let me rephrase it.
If the force is a pull, does it exert pressure Sometimes?, Always?, Never?
Well I am still ignorant of the situation you are refering to, but if the force is capable of pushing or pulling at the surface, then any component of the force perpendicular to the surface will contribute to pressure. Always. If you are refering to pressure of the atmospheric type, then there can be no "pulling", only pushing. So the angle would need to direct the force toward the surface.
Let us suppose there are two identical blocks sitting on the table.
So there is atmospheric pressure Pa acting on the top surface (area A) of each block.
Now suppose we push down onto the top surface of one block with a force F, via say a push rod.
then the total pressue on the top surface of the block is now
Pa + F/A
If we attach a sting to the top surface of the other block and pull up with a force F, that is insufficient to lift the block off the table,
What is now the pressure on the top surface of this block?
Pressure on the top surface would be equal to the pressure on the bottom surface. For the first block the Pa + F/A is the pressure required on the bottom surface to lift the block. For the block with the string it should be Pa - F/A.
So what happens when F/A > Pa ?
pressure will be zero and the resultant force will lift the block.
OK got you. the force only partially contributes to pressure in that case.....The surplus does not :)
Related Threads on Force acting at an angle.
  • Last Post
  • Last Post
  • Last Post
