1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Force and Friction
  1. Feb 17, 2015 #1
    1. A 5 kg block rests on a horizontal table, attached to a 4 kg block by a light string as shown in the figure. The acceleration of gravity is 9.81 m/s 2 .
    The coefficient of kinetic friction between the block and the table is 0.3, find the time it takes for the 4 kg mass to fall 7 m to the floor if the system starts from rest. Answer in units of s.
    2. Relevant equations
    5 kg block = B
    4 kg block = A
    u = 0.3
    g=9.81 m/s^2
    Ff = Force of Friction = u*mass*acceleration
    F = Force = mass*acceleration
    3. The attempt at a solution
    I started by finding the acceleration of the 5kg block using the following equation:
    FB = mB * a = FA - Ff
    Solving for FA:
    FA = (4 kg)(9.81 m/s^2) = 39.24 N
    solving for Ff:
    Ff = (0.3)(5 kg)(9.81 m/s^2) = 14.715 N
    solving for acceleration (a):
    (5 kg) * a = (39.24 N) - (14.175 N)
    (5 kg) * a = 25.065 N
    a = (26.065 N) / (5 kg) = 4.905 m/s^2
    solving for time (t) to reach 7 meters:
    (a*t^2)/2 = 7 m
    a*t^2 = 14 m
    t^2 = (14 m) / (a)
    t = sqrt [(14 m) / (a)] ≈ 1.689 seconds
    The answer comes back as incorrect when I submit it. Any help would be appreciated.
  3. Feb 17, 2015 #2
    Merlin3189
    I think you have not taken account of the fact that the blocks are joined by the string.
    You assume the force on block B = the gravitational force on block A - the frictional force on block B :this is not correct.
    You mark on the diagram a letter T , which I assume is the tension in the string, but you do not use this. (Personally, I would also put on the diagram any forces I do use, such as FA , FB and Ff)
    Remember both blocks move and you need to take account of the acceleration of block A.
  4. Feb 17, 2015 #3
    ok I solved the problem. My original equation was wrong. Apparently since both masses are moving with the same acceleration in this system, and there are only so many newtons to go around, the equation used to find the acceleration looks more like the following:
    Fsystem = (mB+mA) * a = FA - Ff
  5. Feb 17, 2015 #4
    I just copied and pasted this problem out of my homework. That T was already marked. Is there an equation which can relate tension to the solution here?
  6. Feb 17, 2015 #5
    Merlin3189
    Fine. I also solved it as a combined mass, but mentioned the T because you chose to solve for each body separately (which is also ok.) Then T helps because the net force on A is MA.g - T and on B is T - Ff giving two equations and when you add them to eliminate T, the result is the equation you just gave.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Force and Friction
  1. Frictional Forces (Replies: 1)
  2. Friction Force (Replies: 3)
  3. Forces and friction (Replies: 4)
  4. Force of Friction (Replies: 2)
Loading...
