Force and pressure/ upthrust
1)a water tank has a rectangle base of area 5m x 4 m and is 3 m deep. if it is full of water, calculate the thrust on the base and on each side.
2)a model helicopter of mass 5 kg rises with constant acceleration from rest to a height of 60 m in 10 s. find the thrust exerted by the rotor blades during the ascent.
1)density= mass/ volume
pressure = force / area
2) s= (u+v)/t
v= ut + 1/2 at^2
1) weight of water when it is full = 1000 x (3 x4 x 5) = 60000 x 10 = 600000N
upthrust = P= F/A
on sides = 600000/12 = 50000N
base= 600000/ 20 = 30000 N [ ans : 5.9 x 10 ^5, 1.8 x 10 ^5, 2.2 x 10^5 N]
2) thrust force - weight = ma
60=v/2 (10)^2
v= 12 m/s
12= 1/2 (10)^2 a
a= 0.24 m/s^2
thrust force = 5 x 0.24 + 50 = 51.2 N [ans: 55]
Answers and Replies
Doc Al
Mentor
45,093
1,398
upthrust = P= F/A
The 'thrust' is the total force on each side, not the pressure. Hint: Be careful when calculating the force on the sides, since the pressure is not constant.
Good.
60=v/2 (10)^2
That equation should be: d = ½at²; use it to solve for the acceleration directly.
P=F/A
P acting on the base (y) = h rho g = 3 x 1000 x 9.81 = 29500 Pa
F= 29500 x 20 = 5.9 x 10 ^5 N
F acting on the sides (x) = 5 x 1000 x 9.81 x 12 = 5.9 x 10 ^5N
F on (z) = 4 x 1000 x 9.81 x 15 = 5.9 x 10 ^5 N
* why is my upthrust force is different from the answer given?
* out of topic ( i just learnt it today)
- is there any relationship between young's modulus with density?
Doc Al
Mentor
45,093
1,398
P=F/A
This is correct. You calculated the pressure on the bottom, which is uniform. Then used that to calculate the total force.
Not sure what those calculations are doing. What's the average pressure on each side? What's the area of each side?
Not that I know of.
"a water tank has a rectangle base of area 5m x 4 m and is 3 m deep"
let the length = 5m
width = 4 m
height = 3 m
F acting on (x) = F that acting on the sides (left / right)
F acting on Z= F acting on the wall behind/ front
Doc Al
Mentor
45,093
1,398
let the length = 5m
width = 4 m
height = 3 m
I understand the problem. So answer my questions.
arent the pressure is equal on all sides?
the area in the bottom = 5 x 4 = 20 m^2
sides= 3 x 4 = 12 m^2
front= 3 x 5 = 15 m^2
Doc Al
Mentor
45,093
1,398
No. Pressure depends on depth below the surface.
Related Threads on Force and pressure/ upthrust
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
