Force and Work
  • Thread starter mystry4
mystry4
Am I doing this correctly?
If a book that weighs 7 N is picked up off the floor and put on a shelf 2 m high, the work done on the book would be W = Fd (7N)(2m) = 14 J
If the same 7 N book is slid under the bookcase 3 m away, with a pushing force of 5 N and a frictional opposing force of 2 N, then the work done is
F = F(push) - f(friction) = 5 N - 2 N = 3 N then W = Fd (3N)(3m) = 9 J OR
should I be taking the 14 J from the first part and using
W = Fd = (14 J)(3m) = 42 J
Thank you for your help
Answers and Replies
AKG
2,566
Work = Force_applied * distance. Your first attempt at the second question is close, the second is way off. First of all, why would you be using the number from the previous question? In the first one, you're lifting a book, and in this one, you're pushing it. Second of all, 14 J is a measure of work, so how could you use that as your value for force? And why would 14 J x 3 m = 42 J? Look at the units.
mystry4
So, W = Force applied x distance would be 5N(the push) x 3 m = 8J.
The 2N of frictional force is one of those informational numbers and not
one used in the formula?
AKG
2,566
Yes, but 5 x 3 is not 8.
mystry4
Hmm... THAT is what I get for trying to do too many things at once! Of course, 5 x 3 = 15, geez...I need a vacation!
HallsofIvy
43,021
970
Notice that since the applied force (5 N) is greater than the friction force (2 N), the book will not just "slide" under the desk. There will be 2 N "net" force on it which will result in an acceleration. The book will wind up under the desk, not stopped but with a net speed (and so kinetic energy). That's where that additional 9 Joules goes.
Suggested for: Force and Work
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
