Work Done on a Book: 14 J or 42 J?
In summary, the work done on the 7 N book when lifted onto a shelf 2 m high is 14 J. When the same book is pushed 3 m under a desk with an applied force of 5 N and frictional force of 2 N, the work done is either 8 J (calculated correctly) or 15 J (calculated incorrectly). The 2 N frictional force is not used in the calculation, but results in the book having a net speed and kinetic energy when it ends up under the desk.
mystry4
Am I doing this correctly?
If a book that weighs 7 N is picked up off the floor and put on a shelf 2 m high, the work done on the book would be W = Fd (7N)(2m) = 14 J
If the same 7 N book is slid under the bookcase 3 m away, with a pushing force of 5 N and a frictional opposing force of 2 N, then the work done is
F = F(push) - f(friction) = 5 N - 2 N = 3 N then W = Fd (3N)(3m) = 9 J OR
should I be taking the 14 J from the first part and using
W = Fd = (14 J)(3m) = 42 J
Thank you for your help
Work = Force_applied * distance. Your first attempt at the second question is close, the second is way off. First of all, why would you be using the number from the previous question? In the first one, you're lifting a book, and in this one, you're pushing it. Second of all, 14 J is a measure of work, so how could you use that as your value for force? And why would 14 J x 3 m = 42 J? Look at the units.
So, W = Force applied x distance would be 5N(the push) x 3 m = 8J.
The 2N of frictional force is one of those informational numbers and not
one used in the formula?
Yes, but 5 x 3 is not 8.
Hmm... THAT is what I get for trying to do too many things at once! Of course, 5 x 3 = 15, geez...I need a vacation!
Notice that since the applied force (5 N) is greater than the friction force (2 N), the book will not just "slide" under the desk. There will be 2 N "net" force on it which will result in an acceleration. The book will wind up under the desk, not stopped but with a net speed (and so kinetic energy). That's where that additional 9 Joules goes.
1. How is work defined in terms of a book?
Work is defined as the force applied to an object multiplied by the distance it moves in the direction of the force. In this case, it refers to the energy expended in writing or editing the book.
2. What does the measurement of 14 J or 42 J mean in relation to a book?
The measurement of 14 J or 42 J refers to the amount of work done on the book. It represents the energy used to create or modify the book.
3. Is 14 J or 42 J considered a high amount of work for a book?
This depends on the context. In general, 14 J or 42 J may not seem like a lot of work compared to other tasks, but it could be significant in terms of writing a book, which requires a lot of mental and physical effort.
4. How does the amount of work done on a book affect its quality or success?
The amount of work done on a book can have a significant impact on its quality and success. Generally, the more work that is put into a book, the better the quality is likely to be. However, other factors such as writing skill and market demand also play a role in a book's success.
5. Can the amount of work done on a book be measured accurately?
Yes, work can be measured accurately using the formula W = Fd, where W is work, F is force, and d is distance. However, it is important to note that the amount of work done on a book may also include mental and emotional effort, which is more difficult to quantify.
