How to Calculate the Force Applied on a Plate by Another Plate?
In summary, the force applied on the plate is calculated by using Newton's second law of motion, which states that force is equal to mass times acceleration. The factors that affect this force include the mass of the object, its velocity, direction, and external factors such as friction and air resistance. The surface of the plate can also impact the force by increasing or decreasing friction. The direction of the force can change depending on the object's motion or the angle at which it is applied. Finally, the force applied can cause stress and strain on the plate, potentially leading to deformation or breakage.
elmariachi
Hello all,
I was looking to determine the force applied on a plate A by another plate B which is pushing down on plate A to hold it. what are all the information required to calculate the force and how? (see attached pic)
Thanks
  • plate.pdf
Any information about the force applied by plate B?
1. How is the force applied on the plate calculated?
The force applied on the plate can be calculated by multiplying the mass of the object by its acceleration. This is known as Newton's second law of motion, which states that force is equal to mass times acceleration (F = m x a).
2. What are the factors that affect the force applied on the plate?
The force applied on the plate can be affected by various factors such as the mass of the object, the velocity or speed at which the object is moving, and the direction of the force. Other factors such as friction and air resistance can also impact the force applied on the plate.
3. How does the surface of the plate affect the force applied?
The surface of the plate can affect the force applied by either increasing or decreasing the friction between the object and the plate. Smooth surfaces tend to have less friction, resulting in a smaller force, while rough surfaces can increase friction and require a larger force to move the object.
4. Can the direction of the force applied on the plate change?
Yes, the direction of the force applied on the plate can change depending on the direction of the object's motion or the angle at which the force is applied. For example, if an object is pushed from the side, the force will be applied at an angle rather than straight on.
5. How does the force applied on the plate affect the plate itself?
The force applied on the plate can cause the plate to experience stress and strain, which can lead to deformation or even breakage. The type and amount of force applied can also determine the type of stress the plate experiences, such as compression or tension.
  • Other Physics Topics
  • Mechanical Engineering
