Force calclulations on a drum
  • Thread starter wzrdstrm
wzrdstrm
I'm doing some work were its necessary to calculate the force acting on a drum via a wire rope. If I have a known weight acting on the rope already and I want to back calculate the minimum torque necessay for a motor connected to that drum to hold that load, do I add the diameter of the rope to the radius of the drum to do so?
Answers and Replies
Mech_Engineer
172
It depends on how many wraps of cable you have on the drum. In general you will need to take into account the diameter of the wire for a couple of wraps on the drum.
Here's an example in off-road vehicle winching:
http://www.pangaea-expeditions.com/resources/winchworksheet/index.html
Winch capacity
One of the common misconceptions regarding winches is that the maximum rated winch capacity is available any time the winch is hooked up. Unfortunately, this is false. Maximum winch capacity is in fact determined by the number of layers of cable wrapped on the winch drum.
As you can see based upon this chart, the number of layers of cable or winch rope on the drum greatly affects the winch capacity. With the top layer losing almost half the pulling power.
Pkruse
466
What sort of hoist system is this? If a crane or elevator, then all sorts of standards and requirements apply.
wzrdstrm
Simple design only, not for commerical review/standards. We have a motor connected to a gear box (1:1) ratio, connected to a drum that has wire rope wrapped half way across the drum on the root layer (1st layer). What I am expecting is that that if the drum had a root diameter of 100 inches (including lebus grooving) and a roper diameter of 2 inches, for calculation purposes we would have an effective drum radius of 52 inches for the first layer. Is correct?
Pkruse
466
Center of drum to center of rope. 51 inches. But if you measure carefully, the Lebus shell will probably make that number a little different. Just measure total diameter including the rope layer and divide by 2. Then subtract one inch.
wzrdstrm
Confused, why subract one inch? the total diameter would be
2 X Rope diameter + Root Drum Diameter
Suggested for: Force calclulations on a drum
  • Last Post
94K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
