Force exerted by a Basketball
In summary, to calculate the force exerted by a thrown basketball on a friend, the mass of the ball should be multiplied by the acceleration during impact. However, this can be difficult to calculate as it requires knowledge of factors such as the impact time and rebound speed. A rough estimate can be made by assuming certain values for these factors, but they may vary greatly depending on the specific scenario.
Peter G.
442
Say I threw a Basketball at a friend and I wanted to calculated the force it exerted on him, could I do the following? (from an introductory Physics point of view)
Use: F = m x a
1. Weigh the ball
2. Measure the distance between the ball and him, throw the ball and record the time it took for it to hit him: (E.x: He is standing at 10 m away from me, it took the ball 1 second to reach him, it accelerated at 10 m/s2
3. Then, multiply the mass by the acceleration for the Force at which the ball hits him?
Would that work? Thanks!
No. First off, the ball would not be accelerating horizonatlly after it was released from your hand..., if anything, it would be decelerating due to air resistance. But regardless, this has little to do with the force of the ball on him, except for its speed just before impact. But them to calculate the force of impact, you would need to know the time elapsed during impact ( probably just fraction of a second), or the amount of deformation during impact, and the rebound speed at the instant it leaves his body. These would be difficult to calculate. Assume the ball was thrown at 10m/s, rebounded back at 5 m/s, and all this took place during an impact time of 0.05 second , then the average force exerted would be equal to ma, where a is the deceleration of the ball during impact, a= {(-5) - 10}/ 0.05 = - 300m/s/s, and m is about 0.5 kg, so the average force of impact would be about 150 N, or about 30 pounds roughly. These are just rough numbers...if the ball was thrown faster and ir rebounded almost just as fast, and the collision time was shorter, the force could easily be 10 times or more greater than that.
Ah ok thanks. I never understand in which scenario I can use F = m x a
Well, you are using F_net =ma...but the 'a' is the acceleration during impact, not any acceleration before impact. Speaking of impact, what happens when an irresistable force meets an immovable object? Check out this video of a jet slamming at 500 mph into a concrete barrier..designed to test the the missile protection capabilities of a thick walled concrete reactor enclosure...we used to design them for telephone poles being hurled at the dome at 100 mph from a say tornado...or a vehicle at 30 mph...not any more
http://www.crazywebsite.com/Pg-Online-Funny-Videos/F-4-Nuke-Crash-Test-1.html
Yes, this approach would work to calculate the force exerted by the basketball on your friend. The formula F = m x a (force equals mass times acceleration) is commonly used to calculate the force exerted by an object. By measuring the mass of the basketball and the acceleration it experiences while traveling towards your friend, you can calculate the force it exerts on impact. However, it is important to note that this calculation will only give you the average force exerted by the basketball. In reality, the force may vary depending on factors such as the angle at which the basketball hits your friend and the elasticity of the surface it hits. Overall, this is a good starting point for understanding the force exerted by an object in a basic physics context.
1. What is the force exerted by a basketball?
The force exerted by a basketball is the amount of push or pull it applies on an object. It is typically measured in Newtons (N) and can vary depending on factors such as the weight and speed of the ball.
2. How is the force exerted by a basketball calculated?
The force exerted by a basketball can be calculated using the formula F=ma, where F is the force, m is the mass of the ball, and a is the acceleration. This formula is based on Isaac Newton's second law of motion.
3. Does the force exerted by a basketball vary depending on the type of surface it bounces on?
Yes, the force exerted by a basketball can vary depending on the type of surface it bounces on. For example, a basketball will exert more force on a hard, smooth surface compared to a soft, rough surface.
4. How does the force exerted by a basketball affect its bounce?
The force exerted by a basketball directly affects its bounce. The greater the force, the higher the ball will bounce. This is because the force causes the ball to compress and then expand, propelling it upwards.
5. Can the force exerted by a basketball be increased or decreased?
Yes, the force exerted by a basketball can be increased or decreased. It can be increased by applying more force when throwing or dribbling the ball. It can be decreased by reducing the force applied or by using a softer ball.
