Calculating Force Exerted by Gas on Container Walls
In summary, the force exerted by a gas on one wall of a sealed cubical container containing three times Avogadro's number of molecules at a temperature of 23.0°C is 2.73*10^5 Pa.
sun
39
[SOLVED] Force exerted by a gas
A sealed cubical container 30.0 cm on a side contains three times Avogadro's number of molecules at a temperature of 23.0°C. Find the force exerted by the gas on one of the walls of the container.
F=Nm/d(v^2)
P=F/A
There always seems to be a missing variable to plug into the equations. Are there any hints that can get me pointed in the correct direction?
thanks
V of one mole of ideal gas=22.4x10^-3m^3
V of container=2.7x10^-5
T=296K
R=8.31j/mol*k
A=.54m^3
n=?
This is what I've done:
V=m(He)/density(He))
m=.004Kg/(6.02x10^-23*3)=2.21x10^-27kg
V(He)=2.21x10^-27kg/1.79x10^-1Kg/m^3=1.23x10^-26m^3
Am i on the correct path? If so, all i need to figure out is how many moles there are, correct? Then i can solve for P.
does this essentially mean there are 3 moles?
any help would be appreciated :)
I'm not sure how to calculate the moles.
I tried V(f)/V(i)=n(f)T(f)/n(i)T(i)
when i solved for n(i) i got .0011mol. But i guess that isn't correct.
I also tried PV=NkT
would N equal 3*(6.02*10^23)?
If so, what i did was P(.027m^3)=1.81*10^24(1.381*10^-23)(296)
i got 2.74*10^5
Then i multiplied that by the area .54 and got 1.47*10^5N, but that's wrong.
argg still lost and confused
Yes 3 times Avogadro's number means there are 3 moles of the gas. You want to use the ideal gas law with the molar constant R. Thus:
[tex] PV = n R T [/tex]
If you work out the pressure you can find the force exerted on one wall.
this is what I've done:
P(.027m^3)=(3mol)(8.31J/mol*K)(296K)
P=2.73*10^5
F=2.73*10^5(.54)=1.47*10^55 N, but that is incorrect. any idea as to what i may be doing wrong.
And thank you for your help.
do i divide 1.47*10^5 by 6, b/c there are 6 sides to the cube?
The question asks for the force on one side, and the 0.54 you've used is the total area of the box.
EDIT: or you could divide your answer by 6.
YES!
Thank you !
I got it :)
<3
1. What is force exerted by a gas?
Force exerted by a gas refers to the pressure that a gas exerts on its surroundings. It is the result of the constant collisions between gas molecules and the walls of their container.
2. How is the force exerted by a gas measured?
The force exerted by a gas is measured using a device called a manometer, which measures the difference in pressure between the gas and the atmosphere.
3. What factors affect the force exerted by a gas?
The force exerted by a gas is affected by the temperature, volume, and number of gas molecules present. It also depends on the type of gas and the strength of intermolecular forces.
4. How does the force exerted by a gas change with temperature?
According to the ideal gas law, the force exerted by a gas is directly proportional to its temperature. As the temperature increases, the gas molecules move faster and exert more force on the walls of their container.
5. What is the relationship between force exerted by a gas and volume?
According to Boyle's law, the force exerted by a gas is inversely proportional to its volume. As the volume of the gas decreases, the gas molecules are more confined and collide more frequently with the walls of the container, resulting in a higher force.
  • Classical Physics
