Calculating Force from Moving Air: Is it Possible?
  • Thread starter infamous_Q
  • Tags
    Air Force
In summary, the force of air on an object is determined by the relative speed of the object to the air and the shape of the object, which can be approximated using the formulas f = -bv or f = bv². However, the exact formula for calculating this force is dependent on the shape of the object and can involve complex mathematical calculations. The force can also be approximated using the formula P_D = \frac{1}{2}\rho V^2, which calculates the pressure over the entire surface area of the object. To convert this pressure to force, one would divide by the surface area. Further research and understanding of aerodynamics and hydrodynamics may be necessary to accurately calculate the force of air on an object.
infamous_Q
99
is there a way to calculate this?
"Air coming at you" or "you coming at air", that's the same thing. Only the relative speed of you to the air is what matters in determining the force.
Usually, it is reasonable to assume the force of friction with the air is of the form f = -bv, where b is a constant depending on the shape of the body which must be determined experimentally.
Now quoting Symon, pp.36:
"However, for small heavy bodies [...], a better approximation may be f = bv²."
Obviously yes, but from the way your question is worded you are looking for a simple formula. There is none. The force air exerts on an object is extremely dependant on the way air flows around it. That means the shape of the object is very important. If you're really interested, find some good texts on aerodynamics (and/or hydrodynamics). Be warned, some serious math is involved.
Well, in ideal terms, the air resistance is proportional to the cross-sectional area of the object and the square of the speed.
If you want to generalize and treat the object as a flat plate in a fluid stream you can calculate the dynamic head, as in [tex]P_D = \frac{1}{2}\rho V^2[/tex]. Assuming your units are correct, that will give you a pressure which can be used to calculate the force over the entire area.
k thanks everyone..guess I am going to have to do some research huh.
ah and just a quick question..to go from pressure to force i'd just divide the pressure by how big the surface is correct? (since pressure is usually force exterted / area)
1. What is the definition of force exerted by moving air?
The force exerted by moving air, also known as aerodynamic force, is the force that acts on an object when it moves through the air. It is caused by the air particles colliding with the surface of the object and creating a pressure difference.
2. How is the force exerted by moving air measured?
The force exerted by moving air can be measured using a device called a force gauge. This device measures the amount of force required to keep an object in place against the air flow. The unit of measurement for this force is usually Newtons (N).
3. What factors affect the force exerted by moving air?
The force exerted by moving air is affected by several factors such as the speed of the air flow, the density of the air, the shape and surface area of the object, and the angle at which the object is moving through the air.
4. How does the force exerted by moving air affect the flight of an object?
The force exerted by moving air plays a crucial role in the flight of an object. It is responsible for lift, which is the force that allows an object to fly. The amount of force exerted by moving air on the wings of an airplane, for example, determines whether the plane can stay in the air or not.
5. Can the force exerted by moving air be harnessed for practical purposes?
Yes, the force exerted by moving air can be harnessed for various practical purposes. It is used in the design and operation of airplanes, wind turbines, and other aerodynamic devices. It is also utilized in sports such as sailing and kite flying.
  • Other Physics Topics
10K
10K
