Homework Help: Force exerted on a swimmer
  1. Apr 19, 2013 #1
    So the question i have involves finding the force exerted on a swimmer using only arm strokes through the water.
    A snapshot of the swimmer is taken by a camera underwater when the swimmer's arm is vertical and pointing at the camera.
    Here is a diagram of the hand:
    (forgot to label the top stream as A and bottom stream as B)
    The question asks to calculate the Force component that drives the swimmer forward (in this case the x direction), at the time the image was taken.
    Given values are u1=u1A=u1B= 3.5m/s
    d1=d1A=d1B= 20*10^-3 m
    Angle [itex]\alpha[/itex] = 25 degrees
    d2A= 23*10^-3 m
    d2B = 15*10^-3 m
    Given Assumptions
    The effective area of the hand is a rectangle, 0.15m *0.25m.
    The density of water is 1000kg/m^3
    The flow around the time the image was taken is approximately steady.
    The pressure upstream where u1 was measured is the same on both sides of the hand, i.e. P1=P1A=P1B
    The flow pattern is effectively two-dimensional, i.e, you would see the same pattern near the fingertips as near the wrist.
    2. Relevant equations
    A1V1=A2V2
    Bernoulli's Equation form of
    1/2(V2^2-V1^2)=-1/ρ(P2-P1)
    3. The attempt at a solution
    To start off with i found the velocities of each of the flow streams near the end (point 2)
    To do this i used the ratios of the d's to get
    V1A1=V2AA2 (height will be the same so)
    V1d1=V2Ad2A
    V2A= d1/d2A * V1
    and i did the same for V2B
    So the values for the velocities i got were
    V2A=3.04 m/s
    V2B= 4.67 m/s
    Using these values i put them into Bernoulli's Equation
    (V2A^2-V1^2)=-1/ρ(P2A-P1)
    (V2B^2-V1^2)=-1/ρ(P2B-P1)
    sub values and get:
    (P2A-P1)= -1504.2 pascal
    (P2B-P1)= 4779.45 pascal
    I then subbed for P1 and got
    (P2A-P2B)=-6283.65 pascal So this value is the Pressure difference between the flow streams.
    I then used
    (P2A-P2B)*Area(hand) to get the force
    =-235.63 N
    then for the force in the x direction (since the force acts normal to the object)
    -235.63*Cos(115degrees) = 99.58 N
    The value sort of sounds reasonable but I'm not sure if I've made any errors going about this.
    In particular is there anything in the y direction i need to include?
    Any feedback on the working would be appreciated
Draft saved Draft deleted
