What is the Total Force Exerted on a Vertical Dam by Water?
  • Thread starter bcfcdan
  • Tags
    Force
In summary, the conversation discusses the calculation of the overall force exerted on a vertical rectangular dam by water in a reservoir of known dimensions. The correct solution involves finding the average force on the dam by multiplying the pressure at the midpoint of the reservoir by the total area of the dam. However, there is a discrepancy in the answer due to the use of slightly different values for the acceleration due to gravity.
bcfcdan
A vertical rectangular dam of width 25m contains water in a reservoir of depth 15m. What is the overall force exerted on the dam by the water?
P=F/A ... F=PA
P = pgh
I'm really not sure about this one to be honest.
I tried finding the Pressure (1000*9.807*15) and then multiplying that by area (15*25) but that doesn't give the right answer. Any tips would be much appreciated.
Welcome to Physics Forums.
The reason that [itex]F = \rho\cdot A[/itex] does not give the correct answer is that the pressure varies with depth.
Does that help nudge you in the right direction?
Thanks for the reply, so I need to find the Pressure at each point along the Dam?
Which would be (1000 * 9.807 * 1) + (1000 * 9.807 * 2) ... up to 15m?
You could do that, but it would be easier (and sufficient in this case) to find the average force on the damn.
Would that be (1000 * 9.807 * 7.5) * (15 * 25)?
Which gives 27,582kN
Yup :biggrin:
Thanks for your help. Just looked at the answer that we were given for this question and it was 27,590kN.
No problem.
You would have got exactly that answer if you'd have used [itex]g=9.81\;\text{m}\cdot\text{s}^{-2}[/itex].
Ah yes, I thought that might be it. Bit odd considering we get told to use g = 9.807 and then the correct answer is through using it as 9.81!
1. What is the force exerted on a dam?
The force exerted on a dam is the pressure or weight that is applied to the dam by the water it is holding back. This force is caused by the weight of the water and is distributed evenly across the entire surface of the dam.
2. How is the force exerted on a dam calculated?
The force exerted on a dam can be calculated by multiplying the density of water (1000 kg/m3) by the area of the dam and the height of the water above the dam. This will give the total force in Newtons (N) or pounds (lbs).
3. Can the force exerted on a dam change over time?
Yes, the force exerted on a dam can change over time. This can happen due to changes in the amount of water flowing into the reservoir, changes in the water level, or changes in the structure of the dam itself.
4. What are some factors that can affect the force exerted on a dam?
Some factors that can affect the force exerted on a dam include the height and width of the dam, the amount of water in the reservoir, the shape and slope of the reservoir, and the overall stability of the dam structure.
5. How does the force exerted on a dam affect its structural integrity?
The force exerted on a dam is an important factor in determining its structural integrity. If the force exceeds the weight that the dam can withstand, it can cause the dam to fail and potentially lead to catastrophic consequences. Proper design and maintenance are necessary to ensure the force exerted on a dam is within safe limits.
14K
