How Much Force Does a 4 lb Piston Exert When Traveling 6 Inches at 150 PSI?
  • Thread starter JaysAuto
  • Tags
    Force
In summary, force is a physical quantity that describes the push or pull on an object, measured in newtons. It is directly related to the motion of an object and can cause acceleration, deceleration, or change in direction. The formula for force is F=ma, where F is force, m is mass, and a is acceleration. The mass of an object affects the force required to move it, with greater mass requiring greater force. Force can be measured using a force meter or spring scale in units of newtons.
JaysAuto
How much force would a 2.5 inch diameter 4 lb. piston traveling 6 inches pressurized by 150 psi. be hitting a stop? I know the force of a 2.5 inch piston with 150 psi is 736 lbs. I do not know how to calculate the speed & mass traveling 6 inches or 12 inches.
Thanks
Jay
Is there not an answer for this? After reading through these forums with so many intellegent people posting question and answers I do find it hard to believe that someone does not have an idea how to solve it or willing to provide some help.
Thanks
Jay
The force of a moving object can be calculated using the formula F=ma, where F is the force, m is the mass, and a is the acceleration. In this case, the mass of the piston is 4 lbs, and the acceleration can be calculated by dividing the distance traveled (6 inches) by the time it took to travel that distance. However, without knowing the time it took for the piston to travel 6 inches, we cannot accurately calculate the acceleration and therefore cannot determine the force hitting the stop.
To calculate the speed of the piston, we can use the formula v=d/t, where v is the velocity, d is the distance traveled, and t is the time it took to travel that distance. However, this calculation would also require knowing the time it took for the piston to travel 6 inches.
In order to accurately determine the force hitting the stop, we would need to know the time it took for the piston to travel 6 inches. Additionally, the distance traveled (6 inches) does not provide enough information to determine the speed or acceleration of the piston. Without this information, it is not possible to accurately calculate the force hitting the stop.
1. What is force?
Force is a physical quantity that describes the push or pull on an object. It is measured in units of newtons (N).
2. How is force related to a moving object?
Force is directly related to the motion of an object. It can cause an object to accelerate, decelerate, or change direction.
3. What is the formula for calculating force?
The formula for force is F = ma, where F is force, m is mass, and a is acceleration. This formula is known as Newton's second law of motion.
4. How does the mass of an object affect the force?
The mass of an object has a direct impact on the force required to move it. The greater the mass, the greater the force needed to accelerate or decelerate the object.
5. Can force be measured?
Yes, force can be measured using a force meter or spring scale. These tools measure the amount of force applied to an object in newtons.
