Jus' me
- 2
For the question: A 435 n box is sliding down a 40.00 inclined. If the acceleration of the box is 0.250m/s2. Which formula would I use to find just the force of friction? and would I change the Newtons to kilograms?
The force of friction can be calculated using the formula: Ff = μN, where Ff is the force of friction, μ is the coefficient of friction, and N is the normal force.
The coefficient of friction is a dimensionless constant that represents the amount of friction between two surfaces. It is dependent on factors such as the type of materials, roughness of surfaces, and the presence of any lubricants.
The force of friction is directly proportional to the surface area in contact. This means that as the surface area increases, the force of friction also increases.
Yes, the force of friction is directly proportional to the mass of an object. This means that as the mass increases, the force of friction also increases.
Static friction is the force that prevents an object from moving when a force is applied to it. Kinetic friction, on the other hand, is the force that acts against the motion of an object that is already in motion.
