Homework Help: Force on a charge, 4 charges
  1. Sep 15, 2008 #1
    A charge of 5.00 mC is placed at each corner of a square 0.100 m on a side.
    Determine the magnitude of the force on each charge.
    2. Relevant equations
    F= (kq1q2)/r2
    k= 9*10^9
    3. The attempt at a solution
    I drew 4 charges in a square .1m apart from each other, then used the formula above.
    Q1 Q2
    Q3 Q4
    I did the calculation for Q2 (figuring they all should be the same):
    F(2 due to 1) = [(9*10^9)(5*10^-6)^2]/(.01) = 22.5 N
    F(2 due to 4) = [(9*10^9)(5*10^-6)^2]/(.01) = 22.5 N
    F(2 due to 3) = [(9*10^9)(5*10^-6)^2]/(.02) = 11.25 N
    Then:
    Ftotal = ([tex]\sqrt{(22.5^2+22.5^2}[/tex]) + 11.25 = 43.07 N
    Did I do this wrong? Or is the distance from each charge not .1 m?
  3. Sep 15, 2008 #2
    danago
    You seem to have forgotten to square the distances between charges. Also, think again about what the distance between Q2 and Q3 is. The length of the diagonal of a square is not just double the length of each side.
  4. Sep 15, 2008 #3
    I did square the dist between charges, .1^2 = .01
    You're right Q2 to Q3 is not the double of the length of the sides, I used Pythagorean theorem and squared both sides and took the sqrt of that;
    .1^2 + .1^2 = .02
    sqrt .02 = .1414
    but the dist. needed to be squared for the formula so .1414^2 = .02
    lmk if I have mistaken what you posted, and thanks for the reply
  5. Sep 15, 2008 #4
    danago
    Sorry i read the length of the sides as 0.01m instead of 0.1m; my mistake :smile:
  6. Sep 15, 2008 #5
    No worries :). Any more suggestions?
  7. Sep 16, 2008 #6
    Figured it out..... mC does not mean micro it means MILLA!!!! 10^-3 instead of 10^-6
