What is the force direction on the charge placed at the centre?
In summary, the conversation discusses the forces and electric fields present when a point charge is placed at the center of a thin metallic spherical shell containing another charge. The discussion includes the use of Coulomb's law, Gauss's law, and the method of images to explain the symmetric and asymmetric charge distributions on the inner and outer surfaces of the shell. The conclusion is that the charge inside the shell induces a symmetric charge on the surface, while the charge outside induces an asymmetric charge, but overall the electric field inside the shell is zero.
Mr confusion
73
a thin metallic spherical shell contains charge Q on it.A point charge q is placed at its centre and another charge q(1) is placed outside the shell collinear with the charge placed at the centre of the shell.all charges are positive. what is the force direction on the charge placed at the centre?
coulomb law, gauss law
the centre charge will induce some charge on the inner surface of shell. the outside charge is shielded by the metallic sphere.since the centre charge experiences equal forces from all directions ,so it will not have any net force.my problem is that i do not know whether my argument is correct.
I concur: zero net force.
please explain the reasoning by which u arrived at the conclusion u reached,turin. and thanks.
The shell is a conductor. So, the electric field of the external charge cannot make it past the outer surface of the shell. The internal charge induces image charge on the inner surface equally in all directions, so it is attracted equally in all directions. Basically, the same as your reasoning.
Use the method of images.
thanks. but i am still having a problem. since the charge experiences no net force, electric field at the centre must be zero. so net E(at centre)=E(due to surface charges on the shell) +E(due to Q1)=0
since E(due to Q1) is directed towards left, E(due to surface charges on shell) must be towards right.this can only happen if there is an asymmetric distribution of charges. now, how is that happening?
The charge inside the shell at the center will induce a symmetric charge on the surface.
The charge outside the shell will induce an asymmetric charge on the surface. The total charge distribution on the surface will not be uniform.
This happens on the outer surface. Since the charge is distributed on a conductor, it is free to move anywhere it wants in the conductor. So, if there is an electric field in the conductor, it will push the charge around in such a way that the electric field reduces to zero. The conductor effectively isolates the inner surface from the outer suface.
Makes sense. But it seems to me, based on section 2.2 in Jackson, and the image below, that that charge density isn't necessarily uniform.
http://img251.imageshack.us/img251/3838/fig23.gif
You are correct: the charge density is certainly not uniform. However, the point that you must understand is that the charge density is arranged, due to any external charge, in just the right way to make the electric field inside the sphere vanish. So, the only thing that you need to worry about regarding the inside surface is the charge inside, and that situation is symmetrical.
thanks to both of you, the problem is appearing clearer to me now. thanks again.
1. What is the meaning of "force direction" in this context?
The force direction refers to the direction in which a force is applied on an object. In the case of a charge placed at the center, it refers to the direction in which the force is acting on the charge.
2. How is the force direction determined for a charge at the center?
The force direction on a charge at the center is determined by the direction of the electric field at that point. The electric field is a vector quantity that describes the strength and direction of the electric force at a given point.
3. Will the force direction always be the same for a charge placed at the center?
No, the force direction can change depending on the charge and location of other charges in the vicinity. The force direction is affected by the strength and direction of the electric field, which can vary based on the presence of other charges.
4. How does the distance between the charge and other charges affect the force direction?
The force direction is affected by the distance between the charge and other charges because the electric field strength decreases as the distance increases. This means that the force direction can change if the distance between the charges changes.
5. Is the force direction on a charge at the center always opposite to the direction of the electric field?
Not necessarily. The force direction is determined by the charge of the object and the direction of the electric field at that point. If the charge is positive, the force direction will be in the same direction as the electric field, while if the charge is negative, the force direction will be opposite to the electric field.
10K
  • Electromagnetism
