• Support PF! Buy your school textbooks, materials and every day products Here!
Force on a collar
203
1. Homework Statement
Ok guys, me and a few buddy's are stuck on this one. We've got a smooth rod(BC)....and a collar(A) which is free to slide on it. I need to determine the Forces exerted on the collar by the cable, and by the rod....when a force F=900lb is applied to the collar. ***See pic.
2. Homework Equations
I'm not even sure where to start. I've only found the other angle to be 70 degrees.
I think there is a tension and a compression force. I think the tension force this time is on the pipe....while the compression is on the cable. This seems weird....or not how it usually is....but I think its right.
3. The Attempt at a Solution
I've got the actual answers.....but would like to know how to get them....for test purposes.
The answers say T=700lb(I think in the -20, or down direction).
And....Fa = 1316lb (60 deg from the neg x side...upwards and to the left. ).
Thanks for the help and for explaining
Brad
Answers and Replies
cristo
Staff Emeritus
72
What do the other lines on your diagram represent? Could you state the question exactly as it's written please.
203
Question as stated.......The collar A shown in fig3-7....is free to slide on the smooth rod BC. Determine the forces exerted on the collar by the cable and by the rod when the force F=900lb is applied to the collar.
In the area left of B...is like a rock structure(no meaning)....and same as that to the right of C....and the cable(which attaches to the "rock on the right side" at pt D...which I forgot.) The xy axis goes right through center of the collar......and so does the Force.
203
Is this understood now......or need more clearing up?
203
We really need some help on this one guys....there are 3 of us, who don't understand it. Like I said....we've got the answers....just need cleared up, how to actually do it....so we can pass the tests!!! Thanks, and sorry for pushing so hard to get an answer.
I have absolutely no idea what are you asking about... can you explain it more clearly...
What is your force??? its direction??? etc...
Okay.... I guess I understand your question now...
There are 3 Forces act on the collar, which is F (act downward), tension form the cable
(-20 degree to the right, and the normal force from the rod.. since the rod is frictionless, it
must be perpendicular to the rod.....
Do you know the vector notation? if yes, draw a free body diagram for this 3 force...
You have enough equation for all the unknown... make your hand dirty and solve for
them
Related Threads for: Force on a collar
  • Last Post
  • Last Post
