Calculate Force on Golf Ball Impact
  • Thread starter LOannie234
  • Tags
    Force
In summary, a golf ball with a mass of 71.7 g is hit at an angle of 43.1 degrees and lands 122 m away on a flat fairway. The acceleration of gravity is 9.8 m/s^2 and the golf club and ball are in contact for 6.62 ms. To find the average force of impact, you need to find the initial speed and then use it to calculate the acceleration during the impact. Finally, multiply the acceleration by the mass of the ball to find the average force.
LOannie234
A golf ball (m = 71.7 g) is struck a blow that
makes an angle of 43.1 with the horizontal.
The drive lands 122 m away on a flat fairway.
If the golf club and ball are in contact for 6.62 ms, what is the average force of impact?
Neglect air resistance.
i tried to do 71.7(vx-v0x)/delta t and 71.7(vy-v0y)/delta t but i don't know where to go after that
You need to find the initial speed, v.
Then you can find the acceleration during the impact, and multiply by the mass to get the force.
Goodnight! :zzz:​
To calculate the force on the golf ball during impact, we can use the equation F = m*a, where F is the force, m is the mass, and a is the acceleration. In this case, the mass of the golf ball is 71.7 g, or 0.0717 kg. The acceleration is due to gravity, which is 9.8 m/s^2. We also know that the ball is in contact with the club for 6.62 ms, or 0.00662 s.
First, we need to find the horizontal and vertical components of the initial velocity of the ball. We can use trigonometry to do this:
Horizontal component: v_x = v*cos(43.1) = 122 m/s * cos(43.1) = 87.58 m/s
Vertical component: v_y = v*sin(43.1) = 122 m/s * sin(43.1) = 87.58 m/s
Next, we can use the equation d = v_i*t + (1/2)*a*t^2 to find the vertical displacement of the ball during impact. In this case, the initial velocity is v_y = 87.58 m/s, the time is t = 0.00662 s, and the acceleration is due to gravity, a = -9.8 m/s^2. Plugging in these values, we get:
d = 87.58 m/s * 0.00662 s + (1/2)*(-9.8 m/s^2)*(0.00662 s)^2 = 0.29 m
Now, we can use this vertical displacement to calculate the average force of impact using the equation F = m*a. In this case, the mass of the ball is 0.0717 kg and the acceleration is due to gravity, -9.8 m/s^2. Plugging in these values, we get:
F = 0.0717 kg * (-9.8 m/s^2) = -0.7 N
Since we are neglecting air resistance, the average force of impact on the ball is approximately -0.7 N. This means that the ball experiences a downward force of 0.7 N during impact. It is important to note that this value may not be entirely accurate due to the assumptions and approximations made in the calculations. Further experimentation and data
1. What is the formula for calculating force on a golf ball impact?
The formula for calculating force on a golf ball impact is force = mass x acceleration. This means that the force exerted on the golf ball will depend on its mass and how quickly it accelerates.
2. How do you determine the mass of a golf ball?
The mass of a golf ball can be determined by using a scale or balance to measure its weight in grams. The average mass of a golf ball is around 45 grams.
3. What is the average force on a golf ball impact?
The average force on a golf ball impact can vary depending on factors such as the club used, the swing speed, and the angle of impact. However, on average, the force can range from 800 pounds to 2,000 pounds.
4. How does the angle of impact affect the force on a golf ball?
The angle of impact can greatly affect the force on a golf ball. When the ball is struck at a lower angle, more force is directed downward into the ground, resulting in a smaller force on the ball. On the other hand, a higher angle of impact will result in more force being directed horizontally, resulting in a larger force on the ball.
5. Is there a maximum force that can be exerted on a golf ball impact?
Yes, there is a maximum force that can be exerted on a golf ball impact. This is known as the coefficient of restitution, which is the ratio of the final velocity of the ball to its initial velocity. The maximum coefficient of restitution for a golf ball is around 0.83, meaning that the maximum force that can be exerted is about 83% of the initial force.
  • Classical Physics
