1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Force on a point charge due to a rod
  1. Apr 25, 2012 #1
    A rod of length L and total charge Q is a distance D from a point charge q which lies along the
    perpendicular bisector of the rod. Find the force of the rod on the point charge
    2. Relevant equations
    E = ∫ dE
    dq = λdx
    F = qE
    3. The attempt at a solution
    I'm trying to integrate this does the second integral of j go to zero?
    [tex](kQ/L) [i\hat D \int _0L dy/(D^2+y^2)^(3/2) -j\hat \int _0^L ydy/ (D^2+y^2)^(3/2)][/tex]
    sorry for the equation I'm still learning to use latex
  3. Apr 25, 2012 #2
    collinsmark
    The second integral should go to zero due to symmetry. But I don't think you're setting up the limits of integration correctly. The problem statement says the test charge q "lies along the perpendicular bisector of the rod."
    In other words, set up the system in your mind such that the test charge is on one of the axis, a distance D from the origin, and the the rod lies on a different (perpendicular) axis such that the center of the rod is at the origin. Then integrate along the rod from -L/2 to L/2.
    See the link in my signature for a primer in [itex] \LaTeX [/itex] btw.
  4. Apr 25, 2012 #3
    collinsmark
    By the way, as a [itex] \LaTeX [/itex] example, I think the equation you were trying to type in, with limits of integration corrected, is (Right lick on it to see the LaTeX source):
    [tex] \vec F = \frac{kQq}{L} \left[\int_{-L/2}^{L/2} {\frac{D \ dy}{\left(D^2+y^2 \right)^{\frac{3}{2}}} \hat \imath} + \int_{-L/2}^{L/2} {\frac{y \ dy}{\left(D^2+y^2 \right)^{\frac{3}{2}}} \hat \jmath} \right][/tex]
Similar Discussions: Force on a point charge due to a rod
Loading...
