physiker12
- 1
Hello All,
I have noticed that a similar question have been asked many times here, but I still have doubts how to solve the parallel plates problem defined below:
We have two freely moving parallel plates of area A, separated by distance d, one is grounded and the other is supplied with voltage from a regulated power supply which can also have its polarity reversed.
1. What is going to happen to the plates at a given voltage V?
2. What will happen to the plates when changing the voltage with constant speed dV/dt?
3. What will happen to the plates at voltage V when the polarity is suddenly changed?
4. How the problem will change when the plates are replaced with grids?
See below.
1. The plates will attract each other with force F(V,d) = V^2 * e_0 * A / (2 * d^2)
2. As above, but the equation gets more complicated and becomes a function of time. They should meet sooner than in #1.
3. Nothing should happen because of V^2, so sign doesn't play a role. Perhaps I'm underestimating some switching effects here?
4. Again, everything should be the same - to first approximation, ignoring the edge effects and fringe fields near the surface/edges.
Could anyone comment on my answers? Thanks.
See below.
