Homework Help: Force questions
  1. Feb 10, 2010 #1
    What is the value of g on the surface of the earth in Newtons?
    2. Relevant equations
    Fg=G M1M2/R^2
    SumF=ma
    I'm not sure which formula to use?
    3. The attempt at a solution
    i think its (9.80m/s^2)(5.98x10^24)= 5.8604e25 (what does the e on my calculator mean, is this how i would write the answer? something doesnt seem right.
  3. Feb 10, 2010 #2
    cepheid
    Staff Emeritus
    The quantity 'g' isn't measured in newtons. It's an acceleration. So, at least part of this question doesn't make sense.
    You know that, close to the surface of the Earth, it's a pretty good approximation that the weight of an object (i.e. the force with which the Earth's gravity pulls on it) is given by:
    Fg = mg ​
    where 'm' is the mass of the object, and 'g' is the acceleration due to gravity on Earth.
    But you also know that, in general, the gravitational force between two masses M1 and M2 is given by Newton's Law of Gravitation:
    Fg = (GM1M2)/r2
    where 'r' is the distance between the two masses. This second formula applies generally i.e. it is true in all situations. In our situation, one of the two masses is the object of mass 'm', and the other mass is the Earth, whose mass we will label 'ME'. Therefore, we can re-write this formula for our situation as:
    Fg = (GMEm)/r2
    Now, if the second formula is always true, and the first formula (mg) is true when the object is close to the surface of the Earth, and both formulae are giving the gravitational force of attraction between the object and the Earth, then they must both be equivalent, right? Does the fact that these two formulae for calculating Fg must somehow be reconciled give you a hint as to what the defintion of 'g' must be?
    Umm...you are using the value of g (9.80 m/s2) in order to try and calculate the value of g! Does anything about that strike you as logically inconsistent?
    EDIT: In this context, the letter 'e' is calculator shorthand for "times ten to the power of.' For example:
    4.6e5 = 4.6 x 105
  4. Feb 10, 2010 #3
    So you are saying it doesnt matter which formula I use, because they both answer the same question. so it would be Fg= (5.98x10^24)((6.67x10^-11)=3.99x10^14
  5. Feb 10, 2010 #4
    cepheid
    Staff Emeritus
    No, I'm saying that since they both calculate the gravitational force on the object and are both true (near the surface of the Earth), then you should be able to compare them directly. After all, Fg = Fg. From that it will become clear how g must be defined if the two equations are to be consistent with each other.
    Hint: both equations are of the form Fg = m*(something).
