Force required to move a crate
58
You drag a trunk of mass m across a level floor using a massless rope that makes an angle with the horizontal (figure below). Given a kinetic-friction coefficient (mu).
Find the minimum force needed to move the trunk with constant speed.
2. Relevant equations
F=ma
Fk=µk(Fn)
3. The attempt at a solution
What's really getting me is that the site says the answer doesn't depend on theta.
I found the normal force being Fn=mg-FsinΘ
the total friction force being µk(mg-FsinΘ)
For the force equation,
F=ma
F=0
FcosΘ=µk(mg-FsinΘ)
Solving for F, I came up with:
F= (-µkmg)/(µksinΘ-cosΘ)
Again, says no theta in the answer though. Any pointers?
tiny-tim
25,799
242
Hi bakin! :smile:
Yes that's the correct formula …
now find the value of Θ for which it's a minimum. :wink:
58
Well, to get the smallest force value, you want the largest denominator, correct? That would be when cosΘ=0, and sinΘ=1, being pi/2. That would make the answer just -mg. Doesn't make sense to me :(
edit: actually, no. Because if sinΘ=1, and cosΘ=0, the answer would be less than one on the denominator, because it would be µk times sinΘ, giving an answer of 0.XX . I guess then it would be when Θ=0. then, the denominator would be equal to -1, and the answer would be just µkmg?
edit2: I tried putting in µkmg in as an answer before, though, and it wasn't correct. Could I have entered it in wrong or something?
edit3omg: or maybe the angle is pi/4, giving you less pull, but also making the normal force less. not 100% sure.
Aw boo, looks like I need to review the distributive property :blushing:
Ok, so redoing my formula I have the same thing, except all the negatives are now positive.
But, making the denominator equal to one, I'm still left with µkmg, which it said was wrong..
tiny-tim
25,799
242
But, making the denominator equal to one …
uhhh? why? :confused:
Differentiate the bottom, and put it equal to zero. :smile:
58
Doing that gives me tan-1(µk)=Θ ????
But, how would you find this out without differentiating? I'm working on this with a friend of mine, and I don't think her class uses any calculus.
tiny-tim
25,799
242
without differentiating …
you can always rewrite asinΘ + cosΘ in the form b(sinφsinΘ + cosφcosΘ), = b cos(Θ-φ), which is easy to minimise. :wink:
58
Would plugging in tan-1(µk) in for theta be it, or is there another step to that method?
Where did you get φ? Not exactly sure how you went from asinΘ+cosΘ to the other form :uhh:
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
