Force-time graphs?
  • Thread starter gunblaze
hmm...ok.
First, what is a force-time graph?
...How do i read from a force-time graph?
What can i derive from a force-time graph?
any advice? o:)
Answers and Replies
dextercioby
Insights Author
13,081
645
If it's not what i think it is,then it has a very misleading name.It should plot force vs time,or for constant mass,the acceleration vs time...
So what u can derive is simply the characteristics of the movement.
Daniel.
HallsofIvy
41,847
964
Yep. A "force time graph" is exactly what the name says: a graph in which one axis (usually horizontal) shows the time and the other (usually vertical) show the force on an object at the corresponding time.
You can, of course, "read" directly off the graph the force on an object at each time. Since "force equals mass times acceleration", As dextercioby says, if mass is a constant,you can then derive the acceleration of the object. If you are very clever and can calculate the "area under the graph" between two times, that will give you the change in speed between the two times.
ZapperZ
Staff Emeritus
Education Advisor
Insights Author
35,977
4,676
I'm going to stick my nose into this one. Hallsofivy has given you what you can do with the F-t graph, and I, in turn, will tell you WHY you can find, for example, acceleration out of it (assuming that you know basic calculus). I'm in the middle of writing a study guide on why we plot data, and what we can do with graphs. So this would be something I'm going to cover...
Recall that
[tex]F=\frac{dp}{dt}[/tex]
Since we don't know the scenario of your F-t graph, we don't know if the graph was obtained under constant m situation (which is most often the case). So let's first do this without assuming anything. I can then write, using the above equation
[tex]\int F dt = \int dp[/tex]
Now, if you have done calculus you will know that for any function y(x),
[tex]\int y(x) dx[/tex]
is simply the area underneath the y(x) curve.
Thus,
[tex]\int F dt[/tex]
is simply the area under the F(t) curve, and this is equal to the momentum change. This is what is typically known as an Impulse in the limit of very small dt.
Now, what if you do have a constant mass in this situation? Then we know that F=ma, or
[tex]F = m \frac{dv}{dt}[/tex]
Again, doing the same thing, we get
[tex]\int F dt = m \int dv[/tex]
You literally end up with the same thing, i.e. the right hand side is nothing more than
[tex]m(v_f - v_i)[/tex]
where the two v's correspond to the limits of integration. This is nothing more than momentum change for an object with constant mass, a similar conclusion we have drawn from above in the general case. So in this case, you have an additional set of information, that you can also deduce the change in velocity of the object, in addition to knowing the change in momentum.
On the other hand, if you don't know, or not expected to know calculus, then this posting is utterly irrelevant to you. :)
Zz.
dextercioby
Insights Author
13,081
645
College+force-time graph ------>(?) knowledge of calculus.
On the other hand,let's assume for simplicity the constant mass case.Then,by a mere translation || to the Oy/vertical axis,u can get the graph acceleration vs.time.Since time passes anyway,the function a(t) is continuous.If this function is positive,the body of mass "m" is accelerating.If it's zero,then it moves at constant velocity,if it's negative,it's decelerating.If it's constant,bu nonzero,it's either uniformly accelerating,or uniformly decelerating.
This graph can't tell u,however if the body is at rest or moving with constant velocity.Why?Ask Galilei & Newton about the principle of inertia...
Daniel.
Related Threads on Force-time graphs?
  • Last Post
  • Last Post
28K
  • Last Post
10K
  • Last Post
10K
  • Last Post
11K
  • Last Post
25K
  • Last Post
  • Last Post
18K
