Projectile Motion with Pulley System
In summary, the conversation discusses the use of a pulley device to launch a 5.0 kg mass from a ramp with a 30 degree angle. The acceleration of the system is found using the formula (m2g - 0.26*m1g*cos30 - m1g*sin30)/(5+20). The tension in the rope is determined by multiplying the acceleration of the system by m1 and adding the force of kinetic friction. The speed of the projection of the mass is found using the kinematic equations. Finally, the horizontal range is solved as a projectile motion problem. The acceleration of the system is the same for both masses, as they move together as one unit. The force missing in b) is the
EddieV
The pulley device is used to hurl projectiles from a ramp (Coefficient of Kinetic friction [mu] = 0.26) as illustrated in the diagram. The 5.0 kg mass is accelerated from rest at the bottom of the 4.0 m long ramp by a falling 20.0 kg mass suspended over a friction less pulley. Just as the 5.0 kg mass reaches the top of the ramp, it detaches from the rope (neglect the mass of the rope) and becomes projected from the ramp.
The ramp angle is 30 degrees
a) Determine the acceleration of the 5.0 kg mass along the ramp.
b) Determine the tension in the rope during acceleration of the 5.0 kg mass along the ramp.
c) Determine the speed of the projection of the 5.0 kg mass from the top of the ramp.
d) Determine the horizontal range of the 5.0 kg mass from the base of the ramp.
Let m1 = 5.0 kg
Let m2 = 20.0 kg
For a) I know how to solve the acceleration of the system with
So to find the acceleration of just the 5.0 kg block do I use this formula except only divide by 5 instead of 5 + 20. Or is the acceleration of the system also the acceleration of this block?
For b) I am pretty sure you do the acceleration of the system * m1 + Force of Kinetic friction which is 0.26*m1g*cos30
For c) I was thinking of using the big 5, knowing initial velocity is 0, displacement is 4.0 m, and either acceleration of the system or the accelerated I found in a) [unless they're the same acceleration]
For d) I would solve it as a projectile motion problem, I haven't really given it that much thought though
I feel most of my issues boil down to not knowing if the acceleration of the system is the same as the acceleration of the each block independently, and if they are separate values then how do you solve for them.
Thank you and have a nice day!
That is the total force acting on everything. The system moves together as one unit. If the 20 kg mass goes down 1 cm, the 5.0 kg mass goes up 1 cm. The length of the rope by assumption never changes, so they can't have different motions.
That does not represent all the forces acting on m1.
Meaning the standard kinematic equations for uniformly accelerated motion? That should work. I usually try energy considerations first as it's often easiest, but that leads to some of the same equations.
Reasonable, since once it leaves the top of the ramp it's a projectile. But carefully read what distance was asked for.
To clarify, the 5.0 kg mass goes up the slope 1 cm.
Thank you for the help I think I understand a) a lot better for b) though is the force that I'm missing the one that is parallel to the slope of the ramp and a component of the m1g force?
1. What is the difference between a force and motion?
A force is a push or pull on an object, while motion is the movement of an object from one position to another.
2. How are forces and motion related?
Forces cause changes in motion. When a force acts on an object, it can either speed up, slow down, or change the direction of its motion.
3. What are the different types of forces?
The main types of forces are contact forces (friction, air resistance, tension) and non-contact forces (gravity, magnetic, electric).
4. What is Newton's First Law of Motion?
Newton's First Law states that an object will remain at rest or continue to move at a constant velocity unless acted upon by an unbalanced force.
5. How does mass affect motion?
The greater the mass of an object, the more force is needed to cause a change in its motion. In other words, objects with greater mass have more inertia and are harder to move.
