For 2) wouldn't there also be an equal and opposite force on block B by block A?
In summary: When using Newtons law F=ma what does F stand for? Hint... the answer is NOT just "Force".For 2) wouldn't there also be an equal and opposite force on block B by block C?Fnet=ma
Gooner5
Member advised to use the formatting template for questions posted to the homework forums
Three blocks, each of mass 13 kg are on a frictionless table. A hand pushes on the left most box (A) such that the three boxes accelerate in the positive horizontal direction as shown at a rate of a = 1.4 m/s2.
1)What is the magnitude of the force on block A from the hand?
2)What is the net horizontal force on block B?
For number 1 I was able to get the answer by adding up all the blocks and multiplying that by the acceleration but I am confused by why this is right. Before I did this I thought that the answer would be the mass of A * 1.4. Why does the force by the hand on block A include the other blocks as well? Is it because the whole system is accelerating and for that to happen the force has to take into account the other blocks as well?
For number 2 I found the force done on the system to be (13+13+13)*1.4 = 54.6N. I then found that the force that object C does on block B and the force that object A does on block B would 13*1.4= 18.2N. I then added the force done on the system by the hand with block A and subtracted that by the force by C on B to get 54.6, but this is not the right answer. What should I be looking for in this problem?
Thanks
For 1, the hand doesn't care whether it's three separate blocks that happen to be adjacent, or three blocks glued together, or a single block mass 39kg. Alternatively, consider the force pair (action and reaction) at each interface. Each block accelerates according to the net force on it.
For 2), all block B "knows" is that it experiences two forces, one from block A and one from block C, of opposite sign. The net force on B is simply the sum of those two. Alternatively, consider that for each block separately ΣF=Fnet=ma, where the sum is over the forces acting directly on the block. You tried using the first part of that, ΣF=Fnet, to find Fnet (but summed the wrong forces); the alternative is to use the second part, Fnet=ma.
Do you care about that?
I made a typo in my post. Now corrected.
What is a force?
A force is a push or a pull that can change the state of motion of an object.
What are the three laws of motion according to Newton's Law?
The first law states that an object at rest will remain at rest and an object in motion will remain in motion at a constant velocity unless acted upon by an external force. The second law states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. The third law states that for every action, there is an equal and opposite reaction.
How do you calculate the net force on an object?
The net force on an object is calculated by adding all the forces acting on the object in the same direction and subtracting all the forces acting in the opposite direction.
What is the difference between mass and weight?
Mass is the amount of matter an object has, while weight is the force of gravity acting on an object. Mass is measured in kilograms, while weight is measured in newtons.
How does Newton's Third Law of Motion apply in real-life situations?
Newton's Third Law of Motion can be seen in everyday situations, such as when you walk, the force of your foot pushing on the ground causes an equal and opposite force from the ground to push you forward. It also explains the recoil of a gun when a bullet is fired and the movement of a rocket in space.
