Forces and Normal Force
  • Thread starter TS656577
[SOLVED] Forces and Normal Force
In the figure, a crate of mass m = 75 kg is pushed at a constant speed up a frictionless ramp (θ = 32°) by a horizontal force F. The positive direction of an x axis is up the ramp, and the positive direction of a y axis is perpendicular to the ramp. (a) What is the magnitude of F? (b) What is the magnitude of the normal force on the crate?
F=ma
After drawing a free body diagram...there is a movement to the right. F=mg which should mean F=75x9.8 which is 735N. I would think that the Normal Force would be found by F(g)cosx. Im fairly clueless about part A
Answers and Replies
rock.freak667
6,223
31
When you resolve the weight you get mgsin32 down the plane and mgcos32 perpendicular to it right?
The only force acting in the +ve y direction is the the Normal reaction,R. So you know that answer.
Since the motion is up the plane the resultant force is
F-mgsin32=ma
What do you think the resultant force should be equal to while moving at a constant speed?
I am really confused with this
Wouldnt the Normal force be 632.32N? since the gravitational force is -632.32?
rock.freak667
6,223
31
Yes it would.
Resultant force,ma=F-mgsin32
If you are moving with a constant speed up the ramp and your direction is not changing, what does that say about your acceleration?
there is no acceleration?
rock.freak667
6,223
31
Yes that is correct. If there is no acceleration then what is the resultant force acting on it?
Im sorry, but im really just not getting this one
rock.freak667
6,223
31
ok then, we start over.
Do you agree that the force acting down the plane due to the horizontal component of the weight is mgsin(32) ?
A force,F, is pushing the crate up the plane. What is the resultant force here then?
F-mgsin(32) right?
That force would be 632.32 - 389.39?
rock.freak667
6,223
31
Nope.
389.39 is the value of mgsin(32)
632.32 is the normal reaction. Those two forces are in different directions.
But anyhow.
The resultant force =F-389.39
If you are moving with a constant speed and your direction is not changing you aren't accelerating,right?
Then a=0 right?
Now if the resultant force is ma (Newton's 2nd law)
then ma=F-389.39
so it would equal 389.39 if acceleration is 0?
rock.freak667
6,223
31
It would be equal to that because the crate is not accelerating.
Well i put in 632.32 for the Normal force and its apparently wrong
rock.freak667
6,223
31
What is the answer?
I have no idea...i thought it was 632.32
rock.freak667
6,223
31
Then how do you know the answer is not 623.95N?
Theonline program rejected it. Wasnt the other answer 389.39? because if it was, that was rejected as well
F=mg*tan(theta)
mg=mass*gravity
Fn=pithagren theorm
Fn=sqrtroot[(Fnx^2)+(Fny^2)]
Fny=mg
Fnx=F
Related Threads on Forces and Normal Force
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
13K
  • Last Post
  • Last Post
