1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Forces and Tension
  1. Sep 22, 2007 #1
    A 14 kg loudspeaker is suspended 2.0m below the ceiling by two 3.0m long cables that angle outward at equal angles. What is the tension in the cables?
    2. Relevant equations
    F=ma
    3. The attempt at a solution
    I drew the free body diagram, and I broke the tension of the two wires into their components. I'm unsure about how to tackle the problem.
  3. Sep 22, 2007 #2
    learningphysics
    Where are you getting stuck? What are the forces acting on the suspended mass vertically?
  4. Sep 22, 2007 #3
    The forces acting are the tension of the two cables and the weight of the object. I just don't know how to find the angle so I can break up the tensions into components.
  5. Sep 22, 2007 #4
    learningphysics
    Find the angle... you know the y displacement is 2.0m. You know the length of the cable is 3.0m. You can find the angle.
  6. Sep 23, 2007 #5
    Would the angle be 48.19 degrees? And if that's the case, where do I go from there?
  7. Sep 23, 2007 #6
    learningphysics
    I'm getting 41.81 degrees. Well... if T is the magnitude of the tension... what's the vertical component of tension? What are the forces in the vertical direction?
  8. Sep 23, 2007 #7
    The forces in the vertical direction are T1x and T2x
  9. Sep 23, 2007 #8
    learningphysics
    Oops... sorry, this angle is fine... I just got the other angle of the right triangle... 90-48.19 = 41.81
  10. Sep 23, 2007 #9
    learningphysics
    The tensions are equal... So what is Tx in terms of T?
  11. Sep 23, 2007 #10
    Tx = Tcos(theta)
  12. Sep 23, 2007 #11
    learningphysics
    So what is the F=ma equation in the vertical direction?
  13. Sep 23, 2007 #12
    Is it Tcos(theta) = m(ax)?
  14. Sep 23, 2007 #13
    learningphysics
    accleretation is 0... you have 2 tensions... and also gravity.
  15. Sep 23, 2007 #14
    I put horizontal anyway. In the vertical direction it would be Fnety = T1y + T2y - mg = m(ay).
  16. Sep 23, 2007 #15
    learningphysics
    Can you put in the angles, sin/cos etc... ay = 0... and T1=T2... so just use T.
  17. Sep 23, 2007 #16
    I don't understand.
  18. Sep 23, 2007 #17
    learningphysics
    Did you find T?
  19. Sep 23, 2007 #18
    No I didn't. I don't understand how you can find T.
  20. Sep 23, 2007 #19
    learningphysics
    Why are you using two different variables T1 and T2?
  21. Sep 23, 2007 #20
    Am I not breaking the tension into components?
Similar Discussions: Forces and Tension
  1. Tension Force (Replies: 4)
  2. Tension and forces (Replies: 1)
  3. Tension Force (Replies: 1)
  4. Tension Forces (Replies: 2)
  5. Tension and Force (Replies: 3)
Loading...
