Forces Assignment Questions
  • Thread starter whyisad
whyisad
There's an equilateral triangle with three objects on every corner. Corners named A, B, and C.
The mass of each:
A - 5.5 kg
B - 7.5 kg
C- 10.0 kg
The sides of the triangles are also 5.0 cm each.
There are no other forces acting on the corners. How do I calculate the net force experienced by A due to the other two objects, on corners B and C?
Fnet = MA
I couldn't really figure out the question... the only things I did were:
Used Fnet=MA to convert the mass of each corner into newtons
I also realized it was an equilateral triangle, so each corner would be 60 degrees.. and therefore, we could find the exact direction that each corner is pulling towards... not sure if its relevant. They didn't give a mass for the entire triangle either, so I don't think I can find the total mass including the objects at the corners.
Answers and Replies
enkerecz
Are we talking about the force of gravity between the objects?
Or are the objects connected so there will be some tension force on one object due to the other two?
whyisad
The forces of gravity between the objects, likely.
enkerecz
Draw the triangle first and look at it.
You should notice that point masses at either end of the base of the triangle have a force acting at 60 degrees from the top mass, and a parallel force coming from the opposing end of the base. Calculate the force of gravity between each mass, paying attention to the angle it's acting at, and split it into its components. (x)i +(y)j=Fg in vector form. Pay attention the direction and just add up the components that way. Magnitude of the vector is sqrt[(x)i^2+(y)j^2]
Suggested for: Forces Assignment Questions
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
