How Do You Calculate Tension and Acceleration in a Two-Mass System?
In summary, the masses of the blocks in the given figure are M=2.6 kg and m=6.6 kg. The magnitude of acceleration is found to be a=mg/(m+M) and the tension in the cord is T= M-mg +m/(m+M), which may give a negative value due to an error in the algebraic manipulation.
sb13
Suppose that in the figure shown in the URL below, the masses of the blocks are M = 2.6 kg and m = 6.6 kg. What are (a) the magnitude of the acceleration and (b) the tension in the cord?http://www.google.com/imgres?num=10...5&start=0&ndsp=21&ved=0CHkQrQMwDQ&tx=48&ty=63
F= ma
I found the Fnet, y and Fnet, x for the hanging block (H) and for the sliding block (S).
For S Fnet, y = May which becomes FN = FgS, and Fnet becomes T= Ma
For H Fnet, y becomes T-FgH = may, which becomes T-mg= -maI combined the two equations to cancel out T and solve for acceleration.
T-mg+ma = T- Ma
-mg+ma = - Ma
-mg+ma+Ma = 0
ma+Ma = mg
a(m+M) = mg
a = mg/(m+M)
That gave me the correct answer for (a) but when I went to try to cancel out a and solve for tension
T = Ma, T-mg = -ma
a = T/M a= (T-mg)/(-m)
a-T/M = a-(T-mg)/(-m)
-T/M = -(T-mg)/(-m)
(T-mg)/(-m) - (T/M) = 0
M(T-mg)/(-m) - (-m)(T)/M = 0
MT-Mmg/(m+M) -mT/(m+M) = 0
T((M-mg)-m)/(m+M) = 0
T= -M+mg +m/(m+M)
That gives a negative number for tension. What did I do wrong?
Check your algebra
Solving "a-T/M = a-(T-mg)/(-m)" for T doesn't give -M+mg +m/(m+M)
You can even see this from some dimensional analysis
Tension has units of force but on the right hand side you have a mixture of force (mg) and mass terms (-M, -m/(m+M))
What is tension?
Tension is a force that is transmitted through a stretched object, such as a rope, string, or cable. It is always directed along the length of the object and away from the source of the force.
How is tension calculated?
Tension can be calculated using the formula T = F * cos(θ), where T is tension, F is the force applied, and θ is the angle between the direction of the force and the direction of the object being stretched.
What are some real-life examples of forces due to tension?
Some common examples of forces due to tension include pulling a rope in a game of tug-of-war, a weight being lifted by a crane attached to a cable, and a guitar string being stretched by plucking it.
Can tension ever be greater than the applied force?
No, tension can never be greater than the applied force. This is because the tension in an object is always equal and opposite to the force being applied to it.
How does tension affect the motion of an object?
The presence of tension in an object can affect its motion by either preventing or causing it to move. If the tension is greater than the opposing forces, the object will accelerate in the direction of the tension. If the tension is less than the opposing forces, the object will remain stationary or slow down.
