What is the total horizontal force on a constricted pipe with water flow?
In summary: N is the right answer!).To get the force on the pipe, you have to figure out the forces acting on the fluid in the pipe and then apply Newton's 3rd law. You do that by starting with a little fluid segment at the start of the pipe. Bernoulli gives you the pressure and the speed of that segment. Then you know the area and mass density of that segment. So you can work out the force acting on it: P1S1 - P2S2 = F1 - F2. (There is a net force on it because it is accelerating). Then you move the segment further down the pipe and repeat. Eventually you get to the end
danielakkerma
231
(Hello everyone!)
Water is gathered in a column of height h, above above a distributing pipe.
The pipe then narrows from cross sectional area S1 to S2(S1>S2), after which, the fluid exits(as shown in the attached figure)
Find the total horizontal force(in the direction of the fluid's flow) acting on the pipe.
(s1 = 3.0 cm^2, s2 = 1 cm^2, h = 4.6 m).
Bernoulli's law(dynamic pressure):
1. P = rho*v^2/2
The continuity equation 2. v1*s1=v2*s2=const.
I started by defining the force:
Over a certain, small, pressure drop, the (minute) force generated is:
[tex]dF = dP\cdot S(x) [/tex]
Where S(x) is cross-sectional area over the pressure gradient).
I assume that, before the pipe starts to constrict, as the fluid is taken to be ideal(inviscid), there are no force contributions there.
Therefore, according to Bernoulli, a small chance in pressure would be directly related to an alteration of the velocity, by differentiating 1.:
[tex] dP = \rho v dv [/tex]
And from continuity conditions:
[tex] S_1 v_1 = S(x)\cdot v(x) = const \\ v(x) = \frac{S_1 v_1}{S(x)} \\
dv = \frac{-S_1 v_1}{{S(x)}^2}dS \\
[/tex]
Plugging both into dF:
[tex] dF = dP\cdot S(x) = \rho vdv S(x) = -\rho\frac{S_1 v_1}{{S(x)}^2} \frac{S_1 v_1}{S(x)}S(x)dS = -\frac{\rho{S_1}^2{v_1}^2}{{S(x)}^2}dS [/tex]
Integrating, to obtain F, S, going from S1, to S2:
[tex] F = \rho {S_1}^2{v_1}^2 \int_{S_1}^{S_2}\frac{-dS}{{S^2}} = \rho {S_1}^2{v_1}^2 \cdot (\frac{1}{S_2}-\frac{1}{S_1}) [/tex]
Now, since v1 is the velocity the fluid gains from its column, i.e., due to gravity, Bernoulli gives us:
[tex] v_1 = \sqrt{2gh} [/tex]
Inserting all the given data gives me:
(rho is the density of water: 1 g/cm^3)
[tex] F \approx 55 N [/tex]
Yet the correct answer is, F = 6 N!
What have I done wrong?
Any help would be greatly appreciated,
And I am as always thankful for your time and attention,
Daniel
If you show your work (with numbers plugged into formulas) you might get some help in tracking down your error.
Of course. Thanks for your reply.
(You can see the process unfold before(that is, the derivation));
I applied the given data as follows:
Since I had arrived at:
[tex] F= \rho {v_1}^2{S_1}^2(\frac{1}{S_2}-\frac{1}{S_1}) [/tex]
I inserted:
[tex]
\rho = \frac{1g}{{cm}^3} \\
S_1 = 3.0 {cm}^2 \\
S_2 = 1 {cm}^2 \\
v_1 = \sqrt{2gh} = \sqrt{2 \cdot 10 \cdot 4.6 \frac{m^2}{s^2}} \\
[/tex]
Putting all that together:
[tex]
F = \frac{1g}{{{cm}^3}}2 \cdot 10 \frac{m}{s^2} \cdot 460 {cm} \cdot 9 {{cm}^4}(\frac{2}{3}\frac{1}{{{cm}^2}})=55,200 \frac{g \cdot m}{s^2} = 55.2 N [/tex]
Still wrong I fear...
What do you make of all this?
Thank you very much again!
Daniel
Sorry, I am going to have to bump this...
Has anyone got an idea?
danielakkerma said:
Bernoulli gives us:
That would be true if the water were going straight out to atmospheric pressure there. Applying Bernoulli to the transition from surface of water to start of pipe: v12/2+p1/ρ=gh. However, I get 12N, not 6.
Interesting, could you elaborate on that?
I thought that given that the water was still in the beginning, it was simply a question of converting the "weight" of the water to Dynamic pressure.
It's just like water flowing out of a tank, with a hole in one side.
How did you arrive at 12N?(that's pretty close! I may have missed a factor of 1/2, so I'd like to trace your answer, if you would indulge me)...
Thanks again,
I think we're making progress here¸
Daniel
You have to be careful to consider pressure and motion at the same location. If you consider a point at the depth of the pipe but on the opposite side, it will be at the pressure given by the depth, but it won't be moving. If you consider a point at the start of the exit pipe, it will be moving, but its pressure will be lower (as given by Bernoulli). At the end of the exit pipe, we're back to atmospheric and moving faster still. Again, you can set up a Bernoulli equation. So you have two equations and three unknowns (pone pressure, two speeds). Your third equation is that the rate of flow of mass is constant along the pipe.
Haru,
Thanks for your detailed responses, and I'm sorry if I'm stretching this out for far longer than it should be. I very much value your patience with me here.
The problem is, I don't quite see what you mean:
For a small fluid parcel with volume dV, positioned inside the draining pipe(and initially at rest), one could construct the following Bernoulli equality:
[tex]P_1 = P_2+\frac{\rho {v_2}^2}{2}[/tex](No change in height, along the funnelling tube).
So basically, all that's left to be determined is P_1-P_2.
But here's the deal:
P_1(to the "left" of the fluid, towards the basin), has to be: P_atm + P_fluid column:
P_atm + ρgh(there are no other sources of pressure, that I'm aware of).
To the right:
P_atm(the nozzles opens up to air)+0(since the fluid to the right is taken to be still "at rest").
P_atm cancels out.
So where does all this lead?
I would be very grateful if you could show your own derivation, as I am somewhat stuck!
Still, I am very thankful for all your help,
And hoping for some breakthrough,
Daniel
But that is not a feasible combination. If it is inside the pipe it must already be moving. You have to think of the entire tank as part of the flow.
If water enters the pipe at speed V1, pressure P1 (above atmospheric), area S1, and leaves at speed V2, pressure P2 (= atmospheric, i.e. 0), area S2, we have:
gh = V12/2+P1/ρ = V22/2
R (mass flow rate) = V1S1 = V2S2
Whence V2 = √(2gh), V1 = √(2gh)S2/S1, P1 = ρgh(1-S22/S12)
To get the backthrust from the pipe, one way is to compare the applied force at the start of the pipe, P1S1, with the resulting mass*acceleration, ρR(V2-V1). Take the difference of those and you should get 6N (I made a mistake before).
I look at it as follows:
It's the horizontal component of force that matters. So dF = pdS since the area under question is the difference in areas between S+dS and S = dS = 2πr dr, r = radius.
I also figure that according to Bernoulli applied to the tank's surface and the final outlet point 2 is (atmospheric pressure disregarded at both ends)
0 = - ρgh + ρv22/2 → v22 = 2ρgh so working backwards into the pipe,
ρv2(x)/2 + p(x) = ρv22/2 where v(x = 0) = v1.
Combined with S(x)v(x) = S2v2 you can now integrate dF from x = 0 to x = L, L = length of tapered section. S(x) = πr2(x).
I have not done the numbers.
(May be of interest: if you assume an abrupt change in pipe area from 3 cm2 to 1c2, the force works out to 8N. That is very easy to compute & I was hoping it would come out to 6!)
How the cross section depends on distance along the pipe is unknown, so I'd prefer a solution that makes no assumption about that. If you assume it's a cone then S(x) = A(x+B)2.
If no such assumption needs to be made then I would think that I'm entitled to include the limiting case of abrupt aperture transition, in which case I'm fairly confident of my solution of 8N.
You certainly have to assume that the pipe is long in comparison to its width; otherwise flow effects within the tank near the exit become important. Although this is not explicitly stated, it is clear from the accompanying diagram. But I don't see how you get 8N with an abrupt change. Wouldn't you get ρgh(S1-S2), which I calculate as about 9N?
I solved this problem independently, making use of an overall momentum balance as the final step, and got:
[tex]F=\rho ghS_1(1-\frac{S_2}{S_1})^2[/tex] which gives a force of 6 N. As haruspex indicated, it was unnecessary to integrate along the length of the taper. I might also mention that haruspex hinted at using an overall momentum balance, but no one seemed to be very receptive to this idea. Too bad. It seemed obvious to me that this is what was needed.
Of course, this analysis only applies to an ideal (inviscid) fluid.
Chet
F = p1(S1 - S2)
p1 = (ρ/2)(v22 - v12) (Bernoulli along the pipe)
v22/2 = gh (Bernoulli from top of tank to S2)
v1 = v2S2/S1
F = 4.01e4(3e-4 - 1e-4) = 8
CM, does momentum transfer give F = 6 or F = 8 or ?? for an abrupt transition from S1 to S2 do you think?
Guys, everyone, thank you so much!
I've indeed gleaned a great of useful info here, and finally got to the bottom of this.
Haruspex, a special thanks goes out to you, for getting the ball rolling; but everyone, you're all terrific!
Thank you all!
Chet
I got the same thing using ∫Fdt = Δmomentum (can't use p for momentum here! :smile:).
Now to figure out why my abrupt-junction calculation misfired ...
rude man said:
F = p1(S1 - S2)
v1 = v2S2/S1
The overall momentum balance in the axial direction (on the fluid) gives:
[tex]P_1S_1-P_2S_2-F=\rho v_2^2S_2-\rho v_1^2S_1[/tex]
with [itex]P_2=0[/itex] and with [itex]\rho v_2S_2=\rho v_1S_1[/itex]
For an ideal (inviscid) fluid, this gives a value of F = 6N, irrespective of the transition from S1 to S2, provided only that there is enough pipe length following the transition for the streamlines to straighten out again before the fluid exits the pipe.
I'm pretty sure it would be for the reason I gave - it's hard to know the pressure distribution in the approach to an abrupt change because it depends on details of the flow. But I can't be certain without seeing your calculation.
Yes. you are right about that. One can't get the details of the distribution of pressure at the wall without solving the differential flow equations. But that isn't necessary for this problem, since the overall momentum balance delivers the overall integrated force at the boundary, which is all that is asked for. What the overall momentum balance does tell you, however, is that the details of how the channel is tapered are not relevant to the value of the overall force. Of course, if the fluid has viscosity, these results are modified, and the channel taper has at least some effect, since mechanical energy is no longer conserved (i.e., the Bernoulli equation is no longer exact).
See post 15.
But I think my problem was that for an abrupt junction you can't assume streamlines so Bernoulli is not applicable.
rude man said:
See post 15.
Hi Rude Man,
Who says that you can't assume streamlines for an abrupt contraction? My understanding is that, as long as the fluid is ideal, Bernoulli applies. Even with viscous flow, you can assume streamlines.
Chet
Chestermiller said:
Hi Rude Man,
Chet
I would think that, as the fluid bangs up against the abrupt junction, a streamline up to that point is destroyed.
OK then help me figure out what is wrong with my post 15! :smile:
Hi Rude Man,
No way. The streamline along the wall makes a 90 degree turn at the junction and heads downword. As long as the flow is steady and the continuity equation applies, streamlines can be identified. In 2D cartesian coordinates, for example,
[tex]\frac{\partial v_x}{\partial x}+\frac{\partial v_y}{\partial y}=0[/tex]
and you can write:
[tex]v_x=\frac{\partial \psi}{\partial y}[/tex]
[tex]v_y=-\frac{\partial \psi}{\partial x}[/tex]
where ψ is the stream function. This satisfies the continuity equation identically.
The thing that's wrong with post #15 is the force (momentum) balance.
Chet
Chestermiller said:
Hi Rude Man,
Chet
Yes I know but would still like to know what is wrong with my reasoning. It's simply finding p1 by Bernoulli from just to the left of the S1/S2 junction to the outlet, Bernoulli again from the top of the tank to the outlet, then saying F = p1(S1 - S2).
Hi Rude Man,
I think I can explain it to your satisfaction. Let me walk it through. I agree that the force F is solely that acting on the upstream side of the junction, and that the area of the upstream side is (S1-S2). You made the approximation that the pressure on the upstream side of the junction is P1, and, on that basis, you calculated that the force as 8N, rather than the 6N determined exactly (for an ideal fluid) from the overall momentum balance. Therefore, your estimate of the average pressure on the upstream junction surface must have been too high. The average pressure on the junction must be lower than P1. But, why?
Well, in order for the flow to get into the smaller S2 section, the velocity profile no longer remains flat, and, in addition, the flow develops a radial velocity component in order to allow convergence into the smaller channel. As a result, the average vector velocity is higher in the region immediately approaching the junction than further upstream. From Bernoulli, this results in a lower pressure. Another way of looking at this is to consider the very outer streamline. The pressure variation along this streamline determines the pressure distribution on the junction surface. The particles that travel along this streamline have to travel a larger distance than particles that travel down the center of the channel. But they catch up with the particles moving down the center of the channel, so they must be going faster. Again, this results in reduced pressure. The net effect is that, in the problem considered, the average pressure on the junction surface is only about 3/4 P1.
It think that, to flesh this out more quantitatively, we would have to solve the detailed pde's.
Chet
1. What is a force?
A force is a push or pull on an object that causes it to accelerate or change its motion. It is a vector quantity, meaning it has both magnitude and direction.
2. How is force related to Newton's laws of motion?
Newton's laws of motion describe the relationship between forces and the motion of objects. The first law states that an object at rest will stay at rest and an object in motion will stay in motion unless acted upon by an external force. The second law states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. The third law states that for every action, there is an equal and opposite reaction.
3. What is hydrodynamics?
Hydrodynamics is the study of the motion of fluids, such as liquids and gases. It involves understanding the behavior of fluids under different conditions, including the effects of forces such as pressure, viscosity, and turbulence.
4. How do forces affect hydrodynamics?
Forces play a crucial role in hydrodynamics. They can cause changes in fluid pressure, flow velocity, and direction of flow. Forces such as gravity, buoyancy, and drag can also affect the movement of objects through fluids.
5. What are some real-world applications of forces and hydrodynamics?
Forces and hydrodynamics have many practical applications, including in engineering, transportation, and weather forecasting. Some examples include designing efficient airfoils for airplanes, optimizing ship hull shapes for reducing drag, and predicting the path of hurricanes using fluid dynamics models.
