Homework Help: Form p = f(V)
  1. May 11, 2010 #1
    Show that the internal energy of a material whose equation of state has the form p = f(V), T is independent of the volume and the pressure. That is
    [tex]\left(\frac{\partial U}{\partial V}\right)_{T} = 0 [/tex]
    [tex]\left(\frac{\partial U}{\partial p}\right)_{T} = 0 [/tex]
    2. Relevant equations
    TdS = dU + pdV
    3. The attempt at a solution
    I know the answer intiutively, i just dont know how one would go about showing it.
    I assume that U = f(p,v) and then take the partial derivatives, but I do not see where T comes into play
  3. May 11, 2010 #2
    Re: Thermodynamics
    Hmmm, Divide through by dv to get T ds/dv= dU/dv + p I am guessing you need to use a maxwell relation to get ds/dv to dp/dT I don't see how you get the partials to equal 0 though.
  4. May 11, 2010 #3
    Re: Thermodynamics
    I am trying to use the fundamental relation: Tds = dU + pdV and equate it with the partial expansion of U = U(V,p), however, I keep getting stuck because I do not know how to get the relationship of the change in U with either a change in V or p for a given temperature.
  5. May 11, 2010 #4
    Re: Thermodynamics
    not sure this helps but If U=U(V,p) you can use the chain rule to get to dU= (partial U/ partial V) dU + (partial U/partial p) dp
  6. May 11, 2010 #5
    Simple Thermodynamics Problem
    Is this a single variable problem?
