mech-eng
- 828
- 13
Hi, all. I use excel 2010 and when I click on Format as Table there is no " Format as table diaglogbox" which asks "where is the data for your table" but rather discontinous lines under the names light,medium, and dark.
The "Format as table" feature in Excel 2010 allows users to quickly and easily apply a pre-designed table style to their data. This helps to organize and visually enhance the data, making it easier to read and analyze.
To use "Format as table" in Excel 2010, simply select your data range and click on the "Format as Table" button in the Home tab. Choose a desired table style from the drop-down menu and your data will automatically be formatted accordingly.
Yes, you can customize the table style in Excel 2010 by selecting the table and then clicking on the "Design" tab that appears. From there, you can choose from different color schemes, fonts, and table elements to create a personalized look for your table.
The main benefits of using "Format as table" in Excel 2010 are organization and visual enhancement of data. By applying a table style, users can easily distinguish between different data sets and identify patterns or trends. This feature also makes it easier to sort, filter, and analyze data within the table.
Yes, you can convert a regular range of data into a table using "Format as table" in Excel 2010. Simply select the data range, click on the "Format as Table" button, and choose a table style. Your data will be automatically converted into a table with the selected style applied.
