Formula to calculate Newtons
In summary, the person is asking what the distance an object weighing 80kg would need to fall in order to be effected by 4,400 Newtons. The person is trying to find an average drop distance.
bl00d
hi, I am not really sure where this belongs, and being a complete noob at physics, i was just enquiring if someone could inform em of the formula to calculate the distance an object weighing 80kg would need to fall in order to be effected by 4,400 Newtons?
that doesn't make sense.
... do you mean Joules? Have 4400 joules of work done on it by gravity?
i didnt quite think it did, sorry about that.
im doing a project on the death penalty (not a nice topic i know), in particular hanging, and I am trying to find out what an average drop distance is. i can find the amount of force that the rope needs to apply to the neck when the slack is used up (~4,400 Newtons or 450kgf) and a general drop distence, but the actual distance seems to alude my search efforts.
oh. i see. you want the force when the rope snaps. you didn't mention a rope in the OP :)
you would need to know the time interval over which the rope will stop the body. if you can estimate this somehow then you can find the energy/time and get the energy from the distance of the drop.
yeah sorry about that, i just didn't mention it becuase i know some people become quite squeemish about such topics.
an average estimate would be at about 2-3 seconds i guess =S
would you happen to know the formula by the way?
yikes. sorry. I meant momentum/time... heh, wrong units.
Anyways. There are a few things involved. If you can estimate the *time interval* T over which the rope snaps then the force on the neck is given by
P/T
where P is the momentum at the bottom of the fall which is given by
P = m*Sqrt[2 g H]
where H is the distance the body fell, and m is the body's mass and g is the acceleration due to gravity (9.8 m/s^2). Use all SI units.
That is, you want
4400 Newtons = 80*Sqrt[2*9.8*H]/T
If you know the numerical value of T then you can solve for H.
H = ((4400*T/80)^2 )/19.6
P.S., T is probably a lot shorter than 2 or 3 seconds. Probably more like 0.1 seconds.
ah but the rope is between 5 and 9 feet in length for the long drop (to which the Newtons is accurate) that's why i thought it might be longer =\
still a little flabberghasted though :s
Not the DROP time. The drop time, indeed, is about a couple seconds.
T is The STOP time--The time that is take for the rope, at the bottom of the drop, to pull tight.
Yah, it's not the fall that kills you
it's the sudden stop at the end ^_^
Take your fist and punch the nearest wall. Ow. Now punch a block of jello just as hard. Tee-hee. In both cases your fist went from punch speed to 0, what was the difference? When you punched the wall your fist from punch speed to 0 in a fraction of a second.
I'd recommend this only as a thought experiment.
I would definitely recommend punching the jello though
Bill Cosby will be pissed!
What is the formula to calculate Newtons?
The formula to calculate Newtons is F = m*a, where F is the force in Newtons, m is the mass in kilograms, and a is the acceleration in meters per second squared.
How do I calculate Newtons from a given mass and acceleration?
To calculate Newtons from a given mass and acceleration, simply plug in the values into the formula F = m*a. Make sure to use the correct units for mass (kg) and acceleration (m/s^2).
What is the unit for Newtons?
The unit for Newtons is N, which stands for Newtons. It is derived from the formula F = m*a, where the unit for mass is kg and the unit for acceleration is m/s^2.
Can I use the formula to calculate Newtons for any type of force?
Yes, the formula F = m*a can be used to calculate Newtons for any type of force, as long as the mass and acceleration are known.
Is there a different formula to calculate Newtons in different systems of measurement?
No, the formula F = m*a is universal and can be used to calculate Newtons in any system of measurement as long as the units for mass and acceleration are consistent.
  • Classical Physics
  • Classical Physics
