- 21
- 2
. [/B]Hello all !! I am currently trying to make my fortran95 code run in vain.I would really appreciate it if someone could lend my a hand since I am a starter in programming.So the problem goes like that:Create a program capable of calculating the following function: f(x)=1/x when x<3 , x+2(x)^2 when 3≤x≤8 and finally sqrt(x-10) when x>8The problem is that my code will pop up a window 'Error' and it is indicated that the problem is with the square root .Thanks in advance!
.[/B]Mod note: Added code tags.
Fortran:
program function
implicit none
integer::st=0
real::x,y1,y2,y3
print*,'Welcome to the function y=1/x , x<3 &
& 2.*x**2.+x 3<=x<=8 and sqrt(x-10),x>8 '
print*,'input to x'
read (*,*,iostat=st) x
pr:if (st /=0) then
print*,'possible error'
stop
else pr
ex:if (abs(x-3)<1e-6 .or. abs(x)<1e-6) then
y1=1./x
print*,y1
else ex
in: if (abs(x-3)>=1e-6 .and. abs(x-8)<=1e-6) then
y2=(2*x)**2+x
print*,y2
else in
out:if (abs(x-8)>1e-6 .and. abs(x-10)<1e-6) then
print*,'impossible'
stop
else out
br:if (abs(x-10)>=1e-6) then
y3=sqrt(x-10)
print*,y3
end if br
end if out
end if in
end if ex
end if pr
end program
